Question about Car Audio & Video
Auto cd/radio the volume will not turn up/down, change stations
The left side will not work at all but the light is on
    Problem Solver:
  • 5 Answers
You need to use your fade button or control to equal out the sound on both sides.
Posted on Nov 28, 2008
Horn buttons works the radio
Suspect a short circuit in the steering column wiring
Jun 20, 2016 | Cars & Trucks
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Nov 23, 2014 | 1996 Lincoln Continental
On my 2004 X Type Jag only the volume switch works on the radio unit its self cant change stations play cd of use the steering wheel controls as i said all i can do is turn the volume up or down? any ideas...
Did you find the problem with your radio Terry? I have a 2005 X type and the radio has just suddenly started doing exactly the same thing - cant change radio station or use steering controls, only the volume knob works.
Dec 05, 2012 | Cars & Trucks
Cannot tune radio station manually. Only browse by band memory scan, help
Ok to set Manually Turn on radio Select Tuner select band. Press tuning mode button. The window should switch from preset to manual then tune up or down using the tuning preset time buttons left side/ top / Next to volume knob
Nov 03, 2010 | Teac EX-CD3 CD Shelf System
Jensen Phase Linear car radio
Take off the face plate and it is located in the lower left corner
Mar 17, 2008 | Phase Linear 160W AM/FM/CD Receiver W/...
DEH 245 Lights
Try Turning the Power off holding down the clock button till the clock display flashes then use the volume and tuner keys to set the time.
Dec 17, 2007 | Pioneer DEH-245 CD Changer
Volume, Display and FM stations missing?
This could be a bad ground on the radio, or you have serious circuit problems. if a fuse blew, the radio would not work at all. Check the installation first, replace the radio seconds. Good Luck
Jul 29, 2007 | Sony CDX-L420V CD Player
Car Audio & Video Logo
60 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
