Question about LG 42LB1DRA 42 in. LCD Television
Programming wrking fine, however i have no channel guide/listings
How do I fix this?
  • Anonymous Feb 22, 2009
    no longer have on screen listings. left set off for a few days and when I got back, it no longer has listings.
Call LG. They will have you go through diagnostics over the phone and ask for diagnostic data the TV has in memory.
I have done this about 10 times and my TV usually loses all it's TV guide data after I customize my channel listings (delete all the channels I don't susbscribe to). Within a day or two of calling them, my TV Guide is back to normal.
I will never buy another LG TV. Thank God I bought the extended warranty. I've had the power supply already replaced (this is also the 2nd set..replaced 1st set due to same issue), TV turns itself on at times ( in winter - low humidity/static electricity??), and loses TV Guide listings on a frequent basis (after I change the channel map).
Posted on Apr 05, 2009
My lg 65UF6450 has no TV Guide. It searches for active Channels but finds none. Setting them manually doesn't work either. My satellite TV service is on HDMI2 and works fine, just no TV GUIDE.
I have a TV like yours.
When you hook up an external antennae to pick up over the air channels, the TV will find the channels and display a list.
Your other TV services should come with their own channel guides.
Mar 10, 2016 | LG Televison & Video
Tip
Onkyo TX-SR605 Manual Download
Download Onkyo TX-SR605 Manual
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
________________________________________________
RC-682M Remote Code List & Programming Guide Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
We just purchased the Motorola RDU 4100 radios. 8 of them to mix in with 4 others of the same model number. radios were working fine up until recently when 3 of the radios are now broadcasting the same...
Reset to Factory Defaults (Pg. 34)
Reset to Factory Defaults will set back all radio
features to the original factory default settings.
To do so, press PTT, SB2 and SB1
simultaneously while turning ON the radio until
you hear a high tone chirp.
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Programming instructions begin on page 36.
Best regards.
Aug 15, 2011 | Motorola RDU4100 Two Way Radio
Channel lock is stuck on
May 28, 2011 | Televison & Video
How do you change the channel on a motorola cls1110
Here's a link to the user guide: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf
Programming instructions begin on page 26. The CLS1110 is only capable of doing one channel at a time. You can select from the programming list which frequency you want your one channel to be.
Best regards.
Nov 09, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Will not control anything was wrking fine earlier today and now nothing
it lost all its programming if you still have the disc redownload the codes on to the remote if not go to logitechs web site and request another disc or download
Oct 12, 2008 | Logitech Harmony 890 LCD Remote Control
Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Dec 08, 2007 | Panasonic DMR-E85H DVD Recorder
Auto channel programming
The desgin of this unit is such that only the channel being recorded can be viewed. Try to manualy program channel 3 - p.25 in the user guide.. Good luck.
Jan 14, 2006 | Panasonic PV-M2048 20 in. Combo
LG 42LB1DRA 42 in. LCD Television Logo
466 people viewed this question
Computer Repairing
Computer Repairing
