Question about Emerson MW8107WA Microwave Oven
No power - Nothing happens
The microwave simple does not turn on. Nothing on the digital screen, no beeps on the key pad. The light does not come on when you open the door. Nothing. There has not been any power surges in the area and the unit worked fine yesterday with out anything that would suggest that it was going bad. ie; food not heating up normally, key pad not working. I took the top cover off to see if there was a reset button and did not find one. I found a fuse and there is power through the fuse. So I know that I am getting power though the back of the unit and the obvious fuse is working. I am fairly savy with simple electronics but when it comes to the mother board behing the key pad I get a little nervous. Thank you to anyone that is willing to help. Jeff
  • quent523 Apr 05, 2009
    The microwave was working perfectly and just stopped. There is now power at all. The light don't display or the unit doesn't heat up. I tried replacing the fuse but this did not work either.
  • Emerson Master
  • 9,098 Answers
If you have power at the outlet and the internal fuse is okay, I would say you have a problem on the control board. We repair these nationwide for $32.50. Please see my profile for the Web address: http://tinyurl.com/yzjozk
Posted on Jan 21, 2007
Microwave was beeping a single beep once in awhile now nothing happens but the clock still works
A lot of the time when that happens the touch pad is bad and may have a colappsed air pocket on a pad. ( it makes the unit think you are pushing a pad ) The only way to fix it is to replace it (the touch panel) . Did you see any numbers coming up in the display. Like if the 3 pad was bad and making it beep it may have been showing a 3 in the display,. Always possible it could be a bad main board. But most commonly I have found it to be the touch panel. Try to unplug it and then plug it back in and try to set the clock. when you do, try each number pad and see if they all work. See if any feel different.
Oct 17, 2017 | In Microwave Ovens
Screen says "locked" and nothing happens when you
The child lock has been enabled on the microwave. To disable the lock, press and hold 0 until the Locked message disappears from the screen. To set the Lock, press Stop/Clear (to clear the display) and then press and hold the 0 pad until the phrase Lock appears and you hear two beeps.
The manual for the microwave is available here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMC8130DDS&siteCd=JA_EN_US&userType=Consumer . The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208112P218-60.pdf .
I hope this helps.
May 24, 2011 | Jenn-Air JMC8130DDS Microwave Oven
Ge Over The Range Microwave Oven JVM2050...5 yrs. digital clock working so there's power. inside light out and basically digital key pad seems dead.. we had a few flickers of light and a brief turn of...
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 18, 2010 | GE JVM2050 Microwave Oven
Power went out. Microwave just scrolls press clock!!!!!!!!!
Did you figure this out? I am having the same problem. I see PRESS CLOCK on the control display. But none of the keys on the touch pad work. GE sucks bigtime !!
Jan 17, 2010 | GE Spacemaker JVM1540 Microwave Oven
NO HEAT
Circuit board is bad. Cheaper to buy new microwave.
Sep 19, 2009 | Amana AMV1162 Microwave Oven
The key pad doesnt work, had it less than a year. Unplugged and then plugged it back in and it tells me to set the clock but when i push the buttons nothing happens. The key pad isnt locked already tried...
The panel may have a short or need to be tested for replacement. You should try and leave unplugged for 8 hours so power supply can fully drain power and reset microwave
Aug 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400
Key panel (touch pad) shorted.
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave key pad stopped working
Okay, thank you for that.
You have a failed membrane keypad, but on this model, it is not available separately.
You would need to order the control panel assembly, part # WB56X10817, which you can get here for far less than GE charges.
It costs more than just a membrane would, but is much simpler to replace.
Then you remove your circuit board from the old frame and install it in the new frame.
Jan 01, 2009 | Microwave Ovens
Emerson MW8107WA Microwave Oven Logo
392 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
