Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Screen says Printing Online
We are not able to send/receive any faxes
  • Gaitanlaw Jan 02, 2009
    "Printing online" message -won't allow me to copy documents.
    Genius:
  • 2,120 Answers
Make sure the phone cord is plugged into the LINE port of the fax machine.
Check the phone line with a regular phone.
Posted on Nov 26, 2008
5 Suggested Answers
  • 22 Answers
SOURCE: PRINTING ONLINE
Unplug the power cord from the back of the machine for 30 seconds. Put your finger on the stop key first and then re plug the machine, hold the stop key until the time and date return to the LCD. Do not worry about losing any faxes the machine can be powered off up to four days without losing faxes in memory.
Posted on Oct 09, 2007
SOURCE: Won't receive or send
I called Brother Customer Support and they told me to unplug the 4750e and then while holding the stop/exit button plug the fax machine back in. Worked like a charm!!
Posted on Sep 05, 2008
  • 215 Answers
SOURCE: display says "printing online" but it is not connected to a PC
unplug machine, press and hold down the "stop/exit" key while pluggung back in. continue to hold the button down for 5 secs, then release. if machine returns to the regular date/time display, you should be alright. if not, then you'll have to call brother or an authorized service center. this is usually caused by a fax stuck in memory, which this procedure should clear.
good luck,
razors
Posted on Feb 18, 2009
  • 159 Answers
SOURCE: Hi, My office fax machine will not send or
Sounds like a glitch in the memory has left a document there, unable to print. You'll need to clear it out by going into the Maintenance Mode. Maintenance Mode is not mentioned in your user's manual, because there are several functions available that can seriously disable the machine. All you have to do to be safe is follow these instructions to get into the mode, clear the memory, then get out without messing around with other functions.
Press these keys in rapid succession:
Menu
* (the star on the dialing keypad)
6
Do that whole sequence in 2 seconds or less, ignoring all the beeping the machine will assault you with. It's designed to not allow some to accidentally enter Maintenance Mode; if you wait for the beeping to stop, you'll fail, left in some part of the normal menus. When you succeed, the word MAINTENANCE will appear on the display, and all the lights will flash in unison. If that doesn't happen, just touch the STOP button and try again.
Once in maintenance Mode, touch 91 on the number pad. The display will say Initializing or something like that as it clears all the documents form the memory. Your programmed phone numbers and settings will not be affected. When it finishes it will go back to MAINTENANCE. Unplug the power for a few seconds, then plug it back in. The machine should be fine and ready to use.
If Function 91 doesn't work, you should try going back into MAINTENANCE and touch 01 instead. It will clear all memory back to the point it was when you first unboxed the machine. But I think 91 will take care of everything.
Posted on Feb 15, 2011
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Display says "printing online" but it is not connected to a PC
good luck,
razors
Feb 11, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these
instructions to enable fax confirmation before sending any faxes. Select either On
Fax Send or Send & Receive.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Says Printing & Online Stuck
when this happens, unplug machine, hold down the "stop/exit" key while plugging machine in. continue holding the stop/exit key for 5 seconds. display should return to the regular date and time screen. if it doesn't, contact brother customer support. this problem is caused by a fax stuck in memory.
hth,
razors
May 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Try hitting Menu * 2864 (it should say maintenance) then 91 then 99
This will reset the fax machine without erasing your settings. It should clear it up. If it doesn't work after a few tries, you have to hit 0 instead of 91 and that will reset the entire fax machine to factory defaults.
Feb 20, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
PRINTING ONLINE
Sep 21, 2007 | Brother IntelliFAX 4100 Laser Fax
Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
Jul 28, 2006 | Samsung SF-560 Plain Paper Laser Fax
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
