Question about Technics SA-DA10N 5.1 Channels Receiver
No sound I recently bought a used Technics SA-DA10N receiver in working condition but the sound was disappearing from time to time. One time after listening to a CD for 3 tracks the sound disappeared and could not get the sound back till the next day. After couple of days, I was able to listen to sevral CDs without any problem but couple of days ago it finally stopped giving out sound. The display is working and there are no message to indicate there is anything wrong. I even changed the Speakers from A to B but no luck. Any advise would be grately appreciated. Thanks
5 Suggested Answers
SOURCE: technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Posted on Aug 05, 2008
  • 583 Answers
SOURCE: Problem with subwoofer and one off the speakers.
just check if the wires are cut off somewhere or the internal connections loseened up.check this out.
Posted on Mar 13, 2009
davesoucy
  • 148 Answers
SOURCE: receiver sa-590: audio 'cuts out' and now stay
Sounds like the relay are worn. Its small plastic box. You can gently open the cap with precision screwdriver and use fine sand paper, or your gf nails sanding tools and pass it on the contact. If you could unsolder it, its much more easier to open...
Posted on Aug 05, 2009
SOURCE: my technics sa-dx930 receiver stops working and an
Hey, I own one of these systems. Whenever I touch two of the wires together (shorting it out) the system shuts down and overload appears on the display. My suggestion is too check your wiring (especially in the spliced areas) or replace the wiring to the outside speakers and try it again. If you dont want to try that, take the wires you have hooked to the A speakers and see if they will work on the B setting (a quick troubleshooting technique). Please let me know if it worked for you. Good Luck!
Posted on Sep 17, 2009
How should I connect my Technics SA-AX730 receiver to my Panasonic TC-40A420U that uses HDMI?
I assume the Panasonic is a TV. I have never heard of green audio outputs. Audio outputs should be red and white (for RCA plugs). There are adapters available that convert the yellow, red and white component outputs to HDMI. You can get them at GameStop (I bought one recently to connect a game system for my daughter). If you have a TV converter box from your cable or satellite provider you might be able to connect the audio out on the cable box to your Technics receiver and run a HDMI to the TV (be sure to turn off the TV's internal speakers through the TV's menu) for video.
Oct 15, 2014 | Technics SA-AX730 Receiver
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
Receiver sa-590: audio 'cuts out' and now stay
Aug 05, 2009 | Technics Audio Players & Recorders
No left channel sound
check wiring. if ok, swap speaker channels if ok, swap rca plugs, if ok. Bad channel on amp.
Jun 29, 2009 | Technics SA-DA10N 5.1 Channels Receiver
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Technics Receiver SA-DX940 subwoofer
Make sure subwoofer button is pressed and registers that sub is set on, the check dB level adustment for sub channel with remote.
Mar 16, 2009 | Technics SA-DX940
SA-DX940 recently stopped recognizing digital formats
Make sure you are using a digital connection, optical or coaxle cables must be connected, setting on receiver must match cable being used
Dec 18, 2008 | Technics SA-DX940
Missing ac plug for receiver
If the AC plug is the standard "D" shape with the indents for polarization of the cord on both units, yes ou can.
Dan
Mar 25, 2008 | Technics SA-EX510
Technics SA-DX950
sounds like the speaker protection relay is operating probably from a dc condition appearing on power amplifiers outputs. probable cause is dry solder joints to the output stages. will need some reworking of the PA stage soldering to fix.
Dec 10, 2007 | Technics SA-DX950 Receiver
Technics SA-DA10N 5.1 Channels Receiver Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
