Question about Sewing Machines
Does the Singer Fashion Mate 252 use a bobbin case?
  • Sewing Machines Master
  • 7,365 Answers
Yes, it does. if you don't have a bobbin case or need a replacement
check with these sites
sewingpartsonline.com
sew4less.com
if you need a manual check with singer
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 252) & click search
Posted on May 30, 2012
2 Suggested Answers
SOURCE:
  • 980 Answers
SOURCE: bobbin rewind problems
Either the winder rubber is worn down one side, or the spindle has seized, take the top off and check and see if you can turn the winder by hand, if not then it has seized and the only way to free it is to put a couple of drops of WD40 on the spindle, put an electric drill on the end of the spindle and start the drill very slowly.
Posted on Feb 24, 2010
The needle is hitting the bobbin casing in the back. I have re-inserted the needle to make sure it is in properly. I have a Singer 248
Hello Beth
Check the following:
1. Make sure that the needle being used is the correct needle for this machine, refer to page 6 of manual.
2. Yes, insert all the way up ... with flat to the back.
3. Make sure that correct bobbin is being used for this machine. Bobbins not specific for this machine may/will cause problems.
4. Make sure that the bobbin is correctly inserted in the bobbin case. Refer to page 26 of manual.
A free downloadable manual is available at Singer Fashion Mate 248 Instructions Manual Page 31
Please give me a thumbs up if this is helpful, otherwise please send me more information.
Happy stitching
Sewingirl/
Jun 12, 2018 | Singer Sewing Machines
Will the bobbins for my old singer fashion mate work in my new singer one machine?
Most likely, not. However, you can try it and see. Or check what bobbin each machine uses. If they use the same class bobbin, then they are interchangeable.
Search for:
Make Model bobbin
Aug 30, 2017 | Singer Sewing Machines
I have a singer Fashion mate 7256 and when I turn the machine on E 4 comes on the screen. I have looked in my book buy can't find any information on this code! Can you help m
E4 is a bobbin shaft error I believe. In order to clear the message, you need to clean the bobbin case and turn the machine on and off.
Also check the bobbin winder shaft. If it is pushed over when you try to run the machine you may get the error.
Jan 20, 2017 | Singer Sewing Machines
Manual singer fashion mate 252
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 19, 2015 | Singer Sewing Machines
My singer model 237 makes a stitch that doesn't look right. The bottom thread is just goes through the top thread loops under the material
Hi, if stitches are off, there is a problem with balance between the upper and lower stitch adjustments. You have to tweak these. Also, make sure there is no lint in the bobbin case area or under the feeddogs. Here is an excellent blog for 237 Fashion Mate owners. You are lucky to have one of these from the 1960's. http://blog.sew-classic.com/2010/02/02/singer-237-fashion-mate-sewing-machine-reveiw.aspx
Happy Sewing!
Jul 17, 2011 | Singer Sewing Machines
Bobbin rewind problems
Feb 07, 2010 | Singer 8280 Mechanical Sewing Machine
Was given an old model Singer 237 Fashion Mate with no manual. cannot get the bobbin to thread properly.
We'll here is a picture of what I need help on I need to know how to put the needle back along with the needle clamp screw
Jul 09, 2009 | Singer Sewing Machines
Sewing Machines Logo
212 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
