DISC DRAWER WONT OPEN WITH DISC INSIDE - Televison & Video
Went on the forum sites and person told me how to do it
Posted on Nov 27, 2008
My Loewe DVD drawer is stuck closed with a DVD disc inside. How can I open the drawer and retrieve the disc?
Use a knife blade and gently pry the door open, it will work have done it more than once.
Nov 21, 2016 | Loewe Televison & Video
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
My drive wont open.i just get a flashing greenlight when i plug in the unit.
With the unit unplugged, there is a small hole on the front plate. Take a straightened out paperclip and insert it into the hole. push FIRMLY but not too far, and the drawer should pop open about a half inch or so. You will be able to pull it open far enough to remove any disc that may be inside. The disc could be the problem, as drives will hang when trying to read a corrupt disc. I hope this helps.
Oct 08, 2013 | QPS Que! USB 2.0 Drive CD-RW Burner
Dvd drawer wont open
there may be something jamming it inside. 1. unplug, 2. open case. maybe a disc caught inside.
Dec 26, 2010 | Coby KTFDVD1093 TV
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Disc drawer won't open and sometimes doesn't power off
The disc drawer is broken, there are motors that open the drawer (what you hear when turned on and off) and it must of got damaged by a cd or some other way. If you want to open it, pry it open with your fingers or screwdriver. I had to take the 5 cd holders out to see the problem and there was a cd that jammed everything. But you might not have that, take a look. And the "bye bye" thing is normal but not if it wont go off at all.
Oct 06, 2009 | RCA RTD207 System
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Disc drawer will not open
Try to hear a sound of of a running motor inside the unit. If you can hear it, the there's a broken or misplaced rubber belt. The belt drives the drawer open.
Nov 25, 2008 | JVC XL-F254BK 5-Disc CD Changer
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
