Question about HP Compaq Presario V2000 Notebook
Problems with power or battery, not totally sure.
I was having problems with the laptop switching from battery power to outlet power, for about a week. It would be plugged in but anytime I even just slightly moved it would switch. I figured I had problems with my cord so I bought a new one. It just arrived today, I plugged it in and powered up the laptop (which was completly dead) it started right up, no problems. But now it's doing to same exact thing. Right now its on the floor next to me, i'm not even moving it and its still switching back and forth. I don't know what the problem is, but as I use the computer its super important I get it fixed!! I would reeeeeeeeallly appreciate any help anyone could offer. Thanks in advance, Priscilla
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
Sounds like a power pin issue. Most laptop power pins are poorly designed and poorly constructed. Doesn't take much tugging or pulling to break them loose inside and cause problems. The part is only $ 5-10 but the labor to replace the part is $ 100-250 depending on who does the work.
Once you get it fixed you need one of these. . . In fact EVERY laptop needs one of these. . .
Posted on Mar 04, 2008
    Scholar:
  • 163 Answers
What make/model is the unit Prisilla? Weve repaired them all and could give you some extra help if needed.
Posted on Jan 18, 2008
    President:
  • 2,961 Answers
It sounds like a faulty ac power jack connector(where you plug ac adapter in), it may be that it requires re soldering or replacing around the motherboard area. I would take to a local pc repairer for repair or replacement.
Posted on Jan 09, 2007
Nec laptop model
follow this steps and fix it. God bless you
    • 1
Check your laptop's AC adapter. Ensure the laptop's AC adapter is snugly plugged into the port on the back of the . Also, check its connection into either the wall socket or the surge protector, depending on your setup. Make sure the AC adapter is securely in one of these outlets and not loose. Also, if the adapter is plugged directly into the wall, try another outlet. Your existing outlet may be blown.
    • 2
Check your monitor brightness settings. Sometimes these settings get accidentally turned all the way down, which results in what appears to be a dead laptop battery or malfunctioning power supply, but is really just a simple fix. Your laptop has dedicated brightness keys at the top of the keyboard, directly above the numeric keys. Adjust the brightness settings here.
    • 3
Look at the battery indicator light if your laptop appears to be out of battery or suffering a power failure. If it is not flashing or indicating a power problem, your laptop's "LCD closed switch" may be malfunctioning. This switch acts as a sensor which normally judges whether your laptop is open or closed. Sometimes this switch gets stuck in the "closed" position, resulting in the laptop believing it is shut and thus the monitor's back-light staying off. This switch is located right beside either the left or right hinge at the bottom of your laptop's display . Tap this switch multiple times with your finger to attempt to free it up and get it out of the closed position.
    • 4
Consider whether your laptop's battery has completely died and needs to be replaced. Average laptop batteries last for approximately 1000 charges, after which point they either gradual deteriorate and have trouble holding a charge, or simply fail altogether.
Eventually your laptop's battery will have to replaced, and if none of the other troubleshooting steps yielded results this is likely the source of your perceived power supply problems. Flip over your laptop and locate the horizontal outline of the battery, which will be at the top center of the bottom of your computer.
    • 5
Notice the battery release mechanism on the bottom of your laptop, which should be directly below the horizontal outline of the battery. Slide this release mechanism to the left to disengage the battery and gently pop it out. The laptop's power supply may now be replaced.
Jul 31, 2013 | Computers & Internet
Acer TimelineX 3820TG Will Not Power On
make this test and fix it. God bless you
    • 2
    3 Look at the battery indicator light if your laptop appears to be out of battery or suffering a power failure. If it is not flashing or indicating a power problem, your laptop's "LCD closed switch" may be malfunctioning. This switch acts as a sensor which normally judges whether your laptop is open or closed. Sometimes this switch gets stuck in the "closed" position, resulting in the laptop believing it is shut and thus the monitor's back-light staying off. This switch is located right beside either the left or right hinge at the bottom of your laptop's display . Tap this switch multiple times with your finger to attempt to free it up and get it out of the closed position.
      • 4
      • 5
    Jul 25, 2013 | Acer Aspire TimelineX AS5820T-7683...
    Battery doesn't appear to be charging.
    There may be several physical problems. You should make sure that the battery is properly plugged in and no switches that allow it to be removed are in the open position. Checking that the power cord if plugged in proper at the laptop, the power brick, and the power outlet may also solve the problem. If none of these work, try using a different power cord that fits your laptop if you can get your hands on one. You may also want to try a different power outlet, or make sure that power outlet can power another device (eg vacuum, phone) so you know if it's actually a problem with that power outlet and not your computer.
    If you battery doesn't charge even with a cable that you know works for another computer, and the outlet is working properly, your battery may be corroded or suffering from over-use over a long period of time. In this case it would be best to buy a replacement battery directly from Dell which you can do here:
    http://www.amazon.com/Replacement-Laptop-Battery-Studio-7200mAh/sim/B003FZ33SS/2
    Mar 19, 2011 | Dell Studio 17 Laptop
    How to switch on laptaop
    Which laptop do you have.
    On most laptops it would be a button with the symbol.
    Make sure your batteries are completely charged and laptop connected to main's outlet if it is a battery problem. If it is a new laptop better to run off main power and let the battery charge competly.
    Jan 25, 2011 | Computers & Internet
    If your laptop has a bad battery, will the computer still be able to turn on when plugged into a power outlet?
    If your battery is totally drained or dead, your laptop will not turn on even when plugged in to power outlet. The power from the charger don't have enough power to pass through the battery that is trying to charge. Remove the battery and you will be able to turn on your laptop when plugged in directly to wall outlet.
    Sep 21, 2010 | Toshiba Satellite M35X-S163 Notebook
    Hello there, i have problems whether plugging the AC supply into my acer aspire 6920G laptop. when i plugging the AC, the laptop will suddenly shutdown, then boot up again. but when im using battery, it...
    I am sure its totally fault of your OS. Becouse some when ac working well, some where battery. your OS does not recognised your power control properly. Try to use single OS and get batter result. if done thumbs me.
    Dec 16, 2009 | Acer Aspire 6920 Notebook PC
    When i plug in my laptop. it'll turn on for 3 seconds then power off. not sure if its the power cord or the laptop itself.
    i think which device has you connected there is some problem check your device then will your problem will be fix
    Oct 23, 2009 | HP Pavilion zd8000 Notebook
    Couldn't switch on my laptop;adapter light blinking !
    Please take out the battery, and use the AC adapter to boot up only, then put the battery on.
    If any abnormal situation occurs, please do a battery calibration as instructed in the manual. Adapter info:
    Power problems with AC adapter
    Step1 :
    Please remove the battery first to verify the AC adapter's problem
    Step2 :
    Please check the power outlet on the wall by plug another device to the outlet
    Step3 :
    Please plug the adapter directly to the power outlet on the wall
    Step4 :
    Please make sure both the wires between the adapter to the wall and to the notebook are well plugged and the LED on the adapter is alight
    Step5 :
    Please check the power status indicator to make sure whether the notebook is powered on
    Step6 :
    Please make sure whether the CPU fan perform the testing run when the power is switched on
    Step7 :
    Please stick into the hardware reset button at the bottom of the machine and reboot
    Step8 :
    Please remove all of the removable hardware (exp. mouse, PCMCIA card, power adapter, battery, external drives, memory and etc) and install only the necessary components.
    Step9 :
    Please remove the AC adapter and re-install the battery
    Step10 :
    Step11 :
    If possible, please change another battery to make sure whether it's the battery's problem
    Step12 :
    May 04, 2009 | Computers & Internet
    Laptop is not responding
    1) Try holding down the power button for 5 secs. Let go and try to turn it on again. This is a signal that bypasses the OS and tells the motheboard to power down. This helps if the computer is actually still running but with no display.
    2) If that does not work, unplug the computer, remove the battery and leave it at for 1 min. Replace the battery, plug it in and try to turn it on again. Corrupt data in RAM can cause problems like yours, this clears out the RAM so you start fresh.
    If the above did not help it might be your motherboard. A bad motherboard does not usually damage your data. You can remove the hard drive and put it in a portable hard drive enclosure (about $30), the enclose plugs into a USB slot in a working computer and shows up as another hard drive.
    Check to make sure your power is ok, I ran into a situation where the power bar was accidentally turned off and then the battery ran down.
    Jan 08, 2009 | IBM ThinkPad 600X Notebook
    Have power cord plugged into asus eee machine and wall outlet. light has been blinking all day. when asus eee gets unplugged it shuts off.
    lets try this ---
    * turn of your computer
    * remove the plug from your computer.
    * Remove the battery from your computer
    * Let it sit for 3-5 minutes
    * Replace the battery
    * Plug your computer back in (Make sure the wall outlet is working as well, seems simple, but have seen it before)
    * Let it sit for about 3-5 minutes
    * Boot your computer
    * go to
    Start -> Control Panel -> Power Options -> Power Meter
    Note the Total Battery Power Remaining
    * Let your computer sit for 15-30 Minutes and see if the Total Battery Power Remaining has gone up.
    If so problem solved
    if not you may be time for a new battery.
    Dec 26, 2008 | Computers & Internet
    HP Compaq Presario V2000 Notebook Logo
    90 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
