Question about Crimestopper EZ-95FM EzeeStart 2-Way FM/FM Remote Start System w/5-Button R
Ezee start remote stopped working
Replaced battery but still not functioning. most likely needs reprogramming but i can't find any info on reprogramming it. can you help?
related info:
6 blue buttons. 4 on front 2 on right side.
light on front top middle position
"EzeeStart" on front bottom middle position
"FCC ID: CHX433TX" on back bottom middle position
thank you
  • hute73 Jan 16, 2009
    I have the same remote with the same problem. I put in new batteries..still doesn't work. I'm so spoiled by my remote start..any solutions?
  • Anonymous Mar 17, 2014
    batteries in this remote died, after replacing them the remote had to be tapped on the side every so often as if there was something wrong with an internal connection. After 2-3 days of this the remote stopped working all together, the blue indicator light does nothing and there is no response from vehicle. What are my options?
  • 95 Answers
If you have the manuals look under transmitter programming. if not go to crimestopper.com and look under manuals and you can download one from there and follow the steps into reprogramming the transmitter.
Posted on Feb 19, 2009
I changed the batteries now I can get anything to work. The temp is off by 10degrees, my day is reading DON. Help what did I do?
Your year--make--model didn't post for some reason? That info would help.
"my day is reading DON", I don't know what that means?
Some makes and models when battery voltage is lost, there could be some modules that may need to relearn or be reprogrammed. If it needs reprogrammed, you may need to take to dealership? Does the vehicle start and run?
Next time try using a memory saver when you unhook battery, see if it helps?
Jan 10, 2016 | Cars & Trucks
How to reprogram the computer on a 1999 Grand Marquis
You cannot reprogram the computer. You have to replace it. Load test the alternator. If a diode is bad it will charge the battery at a slower rate but will still light the battery warning light.
Dec 18, 2015 | 1999 Mercury Grand Marquis
How can I reprogram a FOB for a KIA CARENS Mk3 LS CRDI 1991cc 03/05/07 ?. Any help will be much appreciated
usually only dealers can reprogram key fobs something about thieves I believe is the reason they give
Jul 10, 2015 | Kia Cars & Trucks
Mopar remote start stopped working
The remote start may now need to be reprogrammed because it needed a slight amount of power from the battery to remember the settings. Replacing the battery interrupted this. Check the manual that came with it.for instructions.
Feb 28, 2014 | Cars & Trucks
How do I reprogram Prostart remote starter/car alarm after replacing car battery?
Try turning the Prostart off, then on with the little toggle switch. Check that the hood pin switch is working as it should
Dec 03, 2013 | Cars & Trucks
Fob not working
If your Suzuki still has its original battery it probably will neeed replacing soon. If your fobs are "smart" it probably will be necessary to reprogram them after the battery is replaced. The current fob failure is likely related to the age of the battery
Oct 24, 2012 | 2009 Suzuki Swift 1.5
My two remotes stopped functioning at the same time.
you have to replace the IR sensor you can order at ebay.
Oct 02, 2012 | LG 37LG30 37 in. LCD HDTV
I have a Sears Chamberlain garage door opener pad outside my garage. The 9V battery died and I have replaced the battery. How do I reprogram the pad?
You shouldn't need to reprogram the pad; it functions as before simply sending a signal to the opener that has the programing saved in it.
May 06, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Saab 2.2tid linear (2003). the central locking system has just stopped working completely, there was no warning to suggest its the battery in the key.. before it stopped working altogether it used...
THE SAAB 9 -3 REMOTE BATTERY HAS TO BE REPLACED AND REPROGRAMMED AT THE DEALERSHIP.THE SAAB 9 - 5 YOU COULD REPLACE REMOTE BATTERY AND REPROGRAM OR SYNCHRONIZATION BY PRESSING REMOTE KEY BUTTON UNLOCK BUTTON AT LEAST 4 TIMES TO REPROGRAM KEY REMOTE TRANSMITTER.
Mar 04, 2011 | Saab 9 3 Cars & Trucks
Crimestopper EZ-95FM EzeeStart 2-Way FM/FM Remote Start System w/5-Button R Logo
2,427 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Frank Mangiapane
Level 1 Expert
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
