Laptop startup problem
Further describing the symtom. When I pushed the ON button, I got lights and fans sounds, but the hard disk seemed not running, and no further response from any keystroke or mouse click.
As for the repair store, can you recommend somewhere in Toronto? Thanks.
Ben
My laptop doesn't turn on.when I pushed the button the hard disk light doesn't black and the screen olso doesn't on...but the laptop fan runs..and other lights also blinks. .
turn off hold f2 button down while restarting . that might get you into the bios so you can reset the system to default , save changes and exit then restart normally .
Aug 25, 2016 | Computers & Internet
Dell studio 1745 wont boot
Look like you might have a display problem...
It is hard to see if you do not have any image on the laptop
If you have another monitor try plugging it in the out display port of the computer to see if you have a visual display on it
Jan 30, 2013 | Dell Studio 1745 (884116033233) PC...
Toshiba L455d s5976 laptop will not bootup black screen
Sounds like the GPU has failed to initialize. Common cause is overheating.
Feb 09, 2018 | Toshiba Satellite Cars & Trucks
Toshiba Satellite L450 black screen on startup no fune sound
OK, you get the yellow light which I assume happens when you plug in the power cord even though you have not pressed the Power Button. So, when you pressed the Power Button, did you see any other lights flashing such as the disk drive light? Did you hear the Fan running and the Disk Drive running? Did you hear the DvD/CD drive click once or the light on the DvD/CD drive door flash? If you did see the aforementioned that means your system is trying to boot and might in fact completed the boot process but the Video is not displaying. If it seems like the computer is running by no video is displaying try shinning a flashlight on the screen to see if you can faintly see the icons or something on the screen. If so that means your LCD Inverter is probably bad and needs to be replaced. You could attach an external monitor to the laptop then press and hold the FN (Function Key) + the (F1 thru F12) key that corresponds to displaying on an external monitor. If the video shows on the external monitor then surely you have an issue with the Laptop's screen. If the laptop is not running and you hear no fans, no disk drive running and saw no lights then you probably have a motherboard issue. Get a quote from your local repair shops, then try the guys at: http://www.generalsystemsconsulting.com. They will repair it and ship it back by Fedex or UPS and most times their prices will beat any quote you find including shipping.
Mar 14, 2012 | Computers & Internet
Laptop will not startup black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 15, 2011 | Acer Aspire One Netbook
Sometime it hangs on the startup when i'm already in the desktop
Please, if you don't have any programs like photoshop or financial program, run system restore.
Then, run anti virus program like kaspersky.
However, make sure you don't hear any noise from your Hard drive or laptop is cool for its best performance.
May 26, 2011 | Toshiba Satellite L645DS4030 Laptop
Laptop running slow and keeps freezing on pages need to reboot system but i dont know how to restart
Hi
could you please tell us the make model and operating system that you are using
and what exactly is wrong with your laptop and is there any particular thing you are doing
on it when it freezes
also has it always been like it or only recently started freezing
many thanks
Mar 06, 2011 | Computers & Internet
My laptop won't start... please
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
Jun 16, 2010 | Toshiba Satellite L25-S119 Notebook
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
When pushed the on button i got lights and fans sounds but the hard disk seemed not running and no further response from any keystroke or mouse click
if I understood correctly, you are trying to power on your laptop and nothing happens.
assuming that it worked before, try the follow:
1. try to turn it on with the power cord connected- if it works it means that your battery is dead
2. take out the battery and try to power it on with only the power cord
3. put back the battery and see if it works
May 19, 2009 | HP Compaq Presario v3000z Notebook
Computers & Internet Logo
49 people viewed this question
Alun Cox
David Payne
David Payne
