Question about CDA CPK9 Stainless Steel Kitchen Hood
Colour of the CDA CHIMNEY HOOD CPX7ss
I ordered this hood which was described as Stainless Steel. It arrived and my fitter installed it while i was on hol. But it is awful as the actual chimney part is not silvery stainless steel but a dull greyish blueish colour which doesn't even look like steel but very cheap and almost plastic like. The actual fan part is lovely with the curved glass and satin stainless steel trim with silver buttons. Is this the normal colour of have I been duped by the online site Appliances Direct.
  • Jan Ravenscroft Nov 26, 2008
    Its ok now... I took off the plastic covering and all was revealed, ha! My fitter was just havin a laugh!
    Sergeant:
    Champion:
  • 338 Answers
The greyinsh blue color sounds like it still has the protective film on it that needs to be peeled off
Posted on Dec 07, 2008
FAN SPEED SWITCH FLASHING F
put fan on then press and hold light button until it stops 2-10 seconds.
Oct 05, 2013 | CDA CPK9 Stainless Steel Kitchen Hood
Screen over chimney?
Screen is not the correct product to use to bird or squirrel proof the chimney. Your local hardware will have what is known as hardware cloth. It's actually a heavy wire mesh with 1/4" or 1/2" square pattern. you should be able to purchase it, by the foot, off a roll.
Jan 06, 2010 | Bosch 36 Inch Pyramid Chimney Hood - Black
Bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Dec 09, 2009 | Bosch DKE93xxUC Stainless Steel Kitchen...
No instructions nor fixings with cooker hood. How do we attatch it? How do we get hold of fixings as staff at wicks were useless. Cookerhood EFC90950X zanussi
you will have to place a straight edge on the top on the hood near the exhaust pipe then mesure from the floor to the bottom of the straight edge, that will give you depth then here is the demisons you have to build the box in. And if you don't have the power there you need to get a contrator or do it yourselfer to install it four you.
Price Range:£342 — £2,084 Average Price:£673 —— Colour body Stainless Steel. Body Material Stainless Steel. Colour chimney Stainless Steel. Typology Built-In. Motor location Integrated Motor. Operating Mode Convertible. Connection Rating (W) 225. Voltage (V) 230. Frequency (Hz) 50. Approval certificates IMQ. Length electrical supply cord (cm) 190. Height of the chimney (mm) 815/1970. Height of product, without chimney (mm) 815. Dimensions of the product, with chimney (if exists) (mm) 815-1970X898X490. Dimensions of the packed product...
Aug 21, 2009 | Electrolux Kitchen Ranges
Install the chimney cover
there should be 2 or 3 peices of alum off the hood predrill hole's then rivet or steel screws
Feb 12, 2009 | Bosch DKE 9365 Stainless Steel Kitchen...
Where do I put the charcoal filter?
It would fit over / into where the other filter goes the charcoal filter is to help eliminate more smoke and grease
Feb 10, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Jan 26, 2009 | CDA Kitchen Ranges
Broan kitchen hood - frenetic chimney
It can be 2 things.
1. The motor that elevates the fan is turning a tad to much. Just by stepping on the floor near it could cause it to go up/down constantly.
2.Or what i had seen was the wires that go to the switch dont have enough slack, and are just making contact to the switch causing it to think somone is pushing the button constantly.
There is way too many steps involved to type out.
Dec 01, 2008 | Broan-NuTone Rangemaster RMDD3004...
Lightbulb Dacor Hood
simply remove filter screen from hood (might as well clean it while it is out), reach your hand through the opening, grasp the light bulb and turn clockwise to remove.
had same problem myself and this is what i did.
Feb 23, 2008 | Thermador 36'' HTSW Series Stainless Steel...
CDA CPK9 Stainless Steel Kitchen Hood Logo
299 people viewed this question
Top CDA Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a CDA Kitchen Range Expert? Answer questions, earn points and help others
