Question about Kenmore 24032\24036 Top Load Washer
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
It goes through the cycles but I often have to do a #2 rinse to have the machine spin and drain. I can hear the motor running but it does not spin and drain. At the end of that cycle, there's a burnt rubber smell.
It will drain sometimes. My topload Kenmore Elite (Heavy Duty, Kingsize Capacity, Ultra Quiet Pack, 3 speed motor with 6 speed combination, Catalyst Cleaning Action, Ultra Rinse) bought in Jul 2002 - would stop after it's first washing cycle, with the "OL" sign blinking on the timer/clock window.
I tried to re-start it, and then it will do the same, stuck after 20 min. cycle.
The problem is, for now, I could not even drain the water-off!
I tried to agitate, pull/turn the ertical spinner, there is no water draining out.
Is there anything, any parts or button that I could push?
Your advise is deeply appreciated. Thank you.
Roger Aninag
  • 2 more comments
  • Anonymous Nov 26, 2008
    how much is a transmission
  • Hulsey Dec 07, 2008
    I had the same problem with My Kenmore Elite Heavy Duty Quiet Pack II. After paying a "repair" man about four times, we changed to another guy who replaced the clutch. Spins fine now. My problem now is during the wash cycle, the agitator isn't turning.
  • Anonymous Dec 20, 2008
    Same problem
  • Anonymous Jan 28, 2009
    It just stops and hums. Push in to stop wait awhile and starts up again.
  • 36 Answers
Check the agitator dogs..remove the cap on the agitater wit a flat head screw driver then remove the screw its a 7/16 screw on there.
pull out the agitator from the bottom...if the dog agits are worned out your agitator wont spin..if those are fine check your transmission.
Posted on Feb 13, 2009
  • 251 Answers
It seems to me ur washer transmission is going out or already there
Posted on Nov 26, 2008
Kenmore washer - water won't drain. It stops
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
Mar 20, 2010 | Washing Machines
I have a kenmore heavy duty, series 70,# 82872120.. It makes a humming noise and will not complete the rinse cycle or the spin cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number and you'll see a list of major sub-components with diagrams and parts.!retrieve.pd?modelNumber=110.82872120
If it goes through the agitate cycle, the motor and transmission are probably OK.
If it goes through the initial drain / spin cycles after the first agitate cycle, the Lid Switch is also OK.
The humming could likely be the timer motor. Try to manually move the timer to the rinse cycle. If the washer responds, the problem points to the timer itself.
See the sub component section on the Sears site for the Console.
The "Alt" part numbers are Whirlpool parts that can likely be purchased from a variety of on line or local parts stores.
Sep 26, 2009 | Kenmore Washing Machines
Washer won't drain
Dear cbringer,
I have the same washer. I have had the same problem with it. It's the timer module. You can get additional help from
Hope This Helps,
Mar 12, 2009 | Kenmore Washing Machines
Washer will not go to the rinse cycel.
check cold water line...onthejob,,,im assuming no rinse cycle only..onthejob,,,no mater the cycle
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
check motor coupler remove motor and check plastic coupler and rubber drive coupler. when you look under machine should see residue on floor from faulty part if this is problem
Nov 21, 2008 | Kenmore 24032\24036 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
Aug 28, 2008 | Washing Machines
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
1,079 people viewed this question
Sal De
 Brian Main
Brian Main
