When i double on the hp solution icon window pops up reading no hp device has been detected
    Genius:
  • 1,913 Answers
Reconnect your printer usb cable yto other usb port on cpu .also check your usb cable.if it is ok .then reinstall hp software and drivers.
Posted on Nov 26, 2008
Printer showing offline
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Jul 10, 2011 | HP DeskJet 6988 Printer
These solutions are unsatisfactory. I have a network and 2 computers (7 and Vista) print, the other says 'printer is offline'. It is Windows 7 and there is no right click option. Maybe it is time to...
First of all we would like to aaplogise for your inconvience.
According to the probelm that you described here there might be many solutions but this will work.
Just read carefully and do the same:-
PC Instructions
  • 1 Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
  • 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Hope this will work.
    But if the problem still persists then get back to here.
    Thank for using FixYa.
    All The Best.
    With Regards:-
    Subhankar Ghosh
    Jan 10, 2011 | HP Office Equipment & Supplies
    USB port not registering
    Try with different USB devices on all the USB ports of your Notebook. Check if those devices which is not detecting in the Laptop, working on other systems.
    (If one of the three is not working, then its a hardware issue). If all the ports are not working, you can try the following steps.
    1:
    1. Disconnect the AC Adapter.
    2. Remove the Battery.
    3. Hold the Power button down for 30 seconds to 1 minute.
    4. Reconnect the AC adapter and do NOT connect the battery now.
    5. Turn on the Notebook power.
    2. Update your BIOS:
    a) Open www.hp.com in the search field type your Laptop product number (eg:AB123UA), can be found on the sticker pasted on the bottom of the Laptop.
    b) Click on Software & Drivers
    c) Select the Operating System (Make sure you are using pre-installed OS only)
    Note: Do not install BIOS on retail or changed OS
    d) Install BIOS and restart.
    3. Re-install USB entries
    1. Save and close all programs that are currently running.
    2. Click Start, select Shut Down, and choose Restart the computer.
    3. Press the F8 function key or the Ctrl key when the HP logo appears. This will display the Windows Startup menu.
    4. Select option 3 to load Windows in Safe mode.
    5. After Windows loads in Safe mode, Click Start and select Control Panel.
    6. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
    7. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
    8. Select the Hardware tab and click the Device Manager button.
    9. In the Device Manager Window, double-click the Universal Serial Bus controllers.
    10. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
    11. Click OK to confirm the removal of the device.
    Restarting the notebook will automatically install the drivers.
    That's it. If there is no luck, your Laptop required an onsite diagnose. Contact HP or local service center.
    Jul 27, 2010 | Compaq Computers & Internet
    I have windowsvista and plugged my hp pcs1210 into my laptop with a usb and my printer box states my printer is offline
    Reference: http://www.ehow.com/how_4796279_change-printer-offline-online.html
    There's a small chance this might be your fix.
    Hope this helps!
  • Step 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Step 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Read more: How to Change a Printer from Offline to Online | eHow.com http://www.ehow.com/how_4796279_change-printer-offline-online.html#ixzz0vK6bYiB5
    May 20, 2010 | HP PSC 1210 All-In-One InkJet Printer
    HOW DO I CHECK INK LEVELS ON HP J6480 ALL IN ONE PRINTER & HP C5280 ALL IN ONE PRINTER??? I USE MS WINDOWS 7 RICKHIGDON@HOTMAIL.COM
    Click on the "Start" menu button which is located on bottom left hand corner of your screen. Click on the "Settings" bar and notice that a list of functions pop up to the left of the settings button. Click on the control panel icon.
    Look for the printer/fax icon in the control panel window. Double click on the printer icon.
    Find the icon for your printer in the opened window and right click on the icon. Now click on the "Preferences" option.
    Look for the menu box pop up with tabs near the top of the box. Click on the "Services" tab.
    Click on "Service this device." You will find the button on the Services menu that you just activated.
    Click on the estimated ink level tab and a graphic will appear indicating how much ink is left in the cartridge.
    Dec 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
    I have an HP Officejet 6310 All-in-One printer. I
    Open the HP Photosmart Software on a Windows computer
    1. Do one of the following:
    – On the Windows desktop, double-click the HP Solution Center icon.
    – In the system tray at the far right of the Windows taskbar, double-click the
    HP Digital Imaging Monitor icon.
    – On the taskbar, click Start, point to Programs or All Programs, select HP,
    and then click HP Solution Center.
    2. If you have more than one HP device installed, select the HP All-in-One tab.
    Note On a Windows computer, the features available in the HP Solution
    Center vary depending on the devices you have installed. The HP Solution
    Center is customized to display icons associated with the selected device. If
    the selected device is not equipped with a particular feature, then the icon for
    that feature does not display in the HP Solution Center.
    From here, you can scan, make copies, and perform maintenance procedures such as checking the ink levels for the print cartridges.
    Nov 16, 2009 | HP Officejet 6310 All-In-One InkJet...
    I have an HP Photosmart 7550 printer. How can I
    First plug the printer to the computer .
    Mar 08, 2009 | HP PhotoSmart 7550 InkJet Printer
    How do I check the ink levels on my HP Photosmart C4480 series?
    Mar 01, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
    No sound .speaker icon has red cross next to it
    HI
    When you point your mouse cursor on it, does it say MUTED? try to right click on it then go to properties or open volume control, uncheck the x or check mark on the box.
    Hope this helps
    Sep 28, 2008 | HP Computers & Internet
    Computer wont react to MP3
    usb doesnt have any drivers
    drivers are for the devices which are connected if the comptuer is not responding to the device there might me various issue
    first the
    check if any other device wd usb port is working or not
    then check the auto play optin
    check weather the device is detected in device manger or not
    then decide wt is wqrong if any other device is being detected by the compter ther will be trouble wd teh mp3 other wise computer
    Jan 31, 2008 | Coby MP-C582 MP3 Player
    37 people viewed this question
    jasbo
    jasbo
