Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Water leak from under fridge when water dispenser is used
I have a GE side by side fridge approx 7 years old. When I try to use the water dispenser no water comes out but it leaks pretty bad from the outside under the unit. Thanks,John
  • tinel Nov 30, 2008
    I have the same issue. did you find a solution yet?
    Tinel
  • skipcallies May 19, 2009
    when water diapenser is used water runs on floor. The water line from the door at the bottom of fridge is missing. The water line going to the freezer door at the floor is it place with the blue connector in place. How do I repair the line in the door?
  • 89 Answers
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Posted on Dec 02, 2008
Why is aSide by side fridge leaking brown liquid from below ice maker?
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
I've had a GE Profile side by side (model # GSS25SGPCSS) with in door water and ice dispenser for approx. 6 years. This week the in door water dispenser stopped working. I removed and replaced the filter...
I have the same fridge and the water line freezes up in the door on a regular basis. I have to use a hair dryer and slowly wait for it to melt. It takes about 30 minutes and then works fine for awhile. It has become quite a habit that I'm not thrilled about. Don't waste your money replacing the board or anything else. GE was no help and I'm now shopping for a new fridge bc of this issue. Needless to say that it won't be a GE! Hope this helps.
Oct 09, 2010 | GE Profile Performance 25.2 cu. ft....
I have a GE side by side refrigerator about 7 years old it has a thru the door ice/water dispenser the water seems to be dropping in the ice tray inside the freezer and freezing in a mass at the bottom of...
Your inlet valve is malfunctioning. Sometimes when they go bad they either let in to much water or none at all. It is located on the back under accesss panel where your water line connects to your fridge. Rate me if I helped you!
Aug 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
Leaking water
the water reservoir tank could be your problem, take out the drawers and operate the dispenser and see if water is leaking from it. if so replacement of the tank is very easy
May 21, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Leak on bottom of freezer on ge profile side by side 13 years old
maytag has several great models and absolytly worth it remeber u get what u pay for . and any fridge u buy get the extened warranty that way no worries for awhile
Mar 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice/water dispenser drips after using
afraid that sounds exactly like the problem.brand new fridge call who you bought it from they should fix it for free good luck hope this solves your problem
Aug 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
569 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
