Question about Pioneer AVX-P7300DVD
Menu display help
My AVX-P7300DVD shows DVD playback perfectly fine, however none of the other menus (ie cd playback controls or am/fm screens)are visible. They work, I can use a cd or listen to the radio, just cant see the menu screens. All dvd functionality is perfect. Any suggestions? Thanks in advance!
  • 3 Answers
Might be the ribbon going out mine did the same till it eventually completely tore, had to order new calbe from pionner to repair
Posted on Mar 18, 2008
SOURCE:
The screen is so dark i can barely make out what is on the screen. i hook up a monitor and that looks fine. my stereo is a pioneer avh-p7480dvd
First I would try pressing the DISPLAY button on your remote which controls the display and if that is not it, it's probably the flex cable. These cables go bad after a while and needs to be replaced. you may also contact Pioneer to see if there is a recall on this part as they may pay for it, otherwise you can purchase it on ebay - http://cgi.ebay.com/PIONEER-AVH-P7480DVD-AVX-P7300DVD-FLEX-RIBBON-CABLE-/120529728036
Mar 09, 2010 | Pioneer AVH-P7480DVD Car DVD Player
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
Feb 05, 2009 | Onkyo TX-SR304 Receiver
I have the remote for my avx-p7300dvd but...... volume
well, maybe u don't have the original control the original one is (CD-R11) and if u do the volume key is located on the side. (rigth side)
Jan 01, 2009 | Pioneer AVX-P7300DVD
Display not working
i have the same unit and when i bought it, the thing that caught my eye 1st was 30,000 hours of use. mine has been back to pioneer usa 3 times thus far. and that was one of the things that was fixed. fortunately, that was under the extended warranty that i purchased.
Aug 05, 2008 | Pioneer AVX-P7300DVD
OWNER MANUAL
everything is controlled for the radio by the little remote. the top right has a source button. press that button a couple of times and watch the screen as you do.
Aug 01, 2008 | Pioneer AVX-P7300DVD
Does the pioneer avx p-7300dvd have am-fm?
hi yes you will need the brain. the tuner is in that.
sorry
Mark
www.blueice-electronics.co.uk
Jul 24, 2008 | Pioneer AVX-P7300DVD
No Sound when playing CD or DVD
Hi, in the menu check that the output is set correctly for dvd playback. ie not through the preout for an amp. It is possible for the unit to be set up to play surround sound for dvd's. Worth a try?
Mar 14, 2008 | JVC KW-AVX800 CD Player
Menu display help..
change the rbg. push that button once and it will take you so that you will be able to view everything. it is probably in dvd mode.
Jan 26, 2007 | Pioneer AVX-P7300DVD
My TFT display screen only shows white. (white, not blue)
Sounds to be defective. All white is not normal under any conditions.
Jan 01, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Pioneer AVX-P7300DVD Logo
94 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
