Question about Carrier Heating & Cooling
What would cause my carrier 52f 108 e air conditioner / heating unit to stop producing enough heat ?
  • 27 Answers
Dirty filter or possible problem with the blower (not running up to speed
Posted on Nov 26, 2008
Ai conditioner compressor will not stop running
I can think of two possibilities. First the main contactor is welded closed and needs to be replaces. Until you call a professional to replace this, turn power off to the entire unit by tripping the breaker.
The other cause for a unit running constantlly, is the unit is trying to satisfy the thermostat and the unit is so undercharged that the unit can not cool or heat fast enough to remove or supply heat depending on cooling or heating mode respectively. Again you will probably need a professional to check your charge.
Hope this helps
Jun 22, 2014 | Goodman CKL49AR49 Air Conditioner
Carrier air con. expansion valve 5 problems and 5 solutions
1. Mid to late 90's problems on Carrier coils leaking. 2. Problem with lication of TXV's on air handlers. When welded in they were located to close to the fitting where the suction lines were welded in to unit. The heat would cause them to fail.
Feb 21, 2010 | Carrier 38CKC042 Air Conditioner
Unit not producing heat but fan cuts on and off
Most newer unit the fan comes on if the limit is tripped. The limit is located in the blower section and in the burner section.
Jan 05, 2010 | Heating & Cooling
Gas emergency heat pump comes on with chemical odor
If the emergency heat doesn't come on very often, it will burn off debris that has collected on the heat exchanger causing the smell. Also, check that there aren't any chemicals that are being stored around the unit that would put out fumes that can be drawn into the system and when heated, cause the odor.
Mar 31, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
Carrier heat pump: aux heat does not seem to work
you have a heat pump which removes heat from outside air when it is too cold out below 30* the unit can no longer produce heat and electric strip heaters kick in
Feb 06, 2009 | Heating & Cooling
Run(heat) for a certain minutes then it stop.
You may have a durty evaporator coil do to a durty filter, the heat is cuting off by the limit control sensor
Feb 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
BLOWER MOTOR PROBLEM
If the thermostat isnt set to fan on, and the temp in the house is ok, there is probabily a fan off delay in the units circuit board thats defective.
Dec 30, 2008 | Carrier 38CKC036 Air Conditioner
Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
59 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
