Question about Gigabyte GA-6VEML Motherboard
Problems with ga-6veml ram
The system only recognize a memory of 32mb, with any other i got a beep and can no tdo anything, i checked all memories that i used and all are ok and also are compatible. if i put the memory of 32mb and any other the system only "see: the first one.
  • luis felipe Jan 15, 2007
    Hi tomj23 I'll be back to you with the beeps combination, thanks a lot for your tips
    Hi Sandrews, It would be possible that teh mother board anly accepted single side ram, I'll lock for it and try till now I only replaced double side sdram, and also I try to put a pair of the same same and speed, in fact it was working with one of 32Mb and the other one 128Mb till star the problem, tahnks also for your help
  • tony_tc1 Apr 21, 2009
    OK, got a gigabyte
    mb. GA-6VEML, but whatever type of memory i put in ,it does not seem to
    reconize them , always giving me less than what is actualy on the
    board. At present i have put in one 256 mb, and one 128mb, but the
    comp. only reads 184mb. with one 256 and one 512 mb i have had around
    360mb give or take. At present it has a celeron 902 ghz.CPU. any
    idea's. thanks Tony.(by the way running on XP .)
    President:
  • 2,961 Answers
As Tom quite rightly says, the beep codes are a clue, but, could i add to the Tom's very helpfull solution, that; it may be your motherboard only supports, either double sided or single sided ram, and the memory sticks may well have to e a matched size pair, e.g 2 x 32mb. If you install different speeds of ram, the faster one will only run at the slower ones speed.
Posted on Jan 09, 2007
  • 624 Answers
Hi Luisfe, Your motherboard will only support a maximum of 1GB DRAM and only supports 168 pin, PC-100 or PC-133 SDRAM and VCM SDRAM at 3.3 volts. As long as your modules meet these requirements they should work. Specifically what size and specification modules are you inserting in your two memory sockets? Also when you power up with these modules installed you mentioned you hear beeping. These are *beep error codes*, if you tell us what combination of short and long beeps you hear that will probably help the diagnosis. Once I receive this information I?ll try to help you figure out what?s going on.
Posted on Jan 08, 2007
SOURCE:
GigaByte GA-8EGXR-P motherboard beeps when turned on - no video or BIOS - system does not boot
hi try to clean memory ram....clean it using eraser.....most of motherboard beep if memory not detected....or try other memory ram
May 10, 2011 | Gigabyte GA-8EGXDR-EL Motherboard
Having installed this motherboard in the case and connected up I get a series of fast beeps a few seconds after power-up. I have immediately powered down. What is causing this problem? There is nothing in...
In your case, it is a memory problem. It's either one of your RAM has problem if you have 2 slot RAM. Please ensure that you have the right RAM for your board. You can also clean the contacts of your RAM by using eraser.
Below are the most common beep code that being adopted to most BIOS for reporting.
  • short beep - Normal POST(system is OK)
  • Steady short beeps - power supply problem
  • long continuous beep - memory failure
  • Steady long beeps - power supply problem
  • 1 long, 2 short beeps - video card problem
Apr 06, 2011 | Gigabyte GA-G41M-Combo Motherboard
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Memory won't add on a Gigabyte GA-6VEML
this will be dependant on the bios version. or if the 2 ram modules are identical or not. if they,re a matched pair. the motherboard may not like or run in dual-channel mode. sometimes adjustable in the systems bios. the other suggestion, is to try 1 stick of ram, in each slot individually. This will eliminate A Faulty Slot. Failing any Of The Above. try 2 x 256mb sticks, And Obtain The Latest Bios Update from The Manufacturers Website.
Mike @ Compurepair.
Oct 28, 2009 | Intel Motherboard
4 long beeps. what is the error?
Four long beeps indicates a RAM (memory) problem.
Take out the system memory, clean the brass pins and the RAM slots with a clean, dry, soft paintbrush then reseat the memory.
If it still won't boot up the RAM may need to be replaced.
Regards.
Jul 29, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
When I turn on my computer i hears a few double beeps and I don't see anything on my monitor while computer sounds like it running
Here is a link for with some information for the GA-M55plus-S3G motherboard:
http://china.giga-byte.com/FileList/Manual/motherboard_manual_ga-m55plus-s3g_3.x_e.pdf
The below was taken out of the document:
The beep codes below may help you identify the possible computer problems. However, they are
only for reference purposes. The situations might differ from case to case.
�� AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Jul 07, 2009 | Gigabyte GA-M55plus-S3G Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
About ddr
Some motherboards require identical RAMs to be installed on them but some doesn't this could be causing the problem in your case. At the very least, try to re-seat the RAM and hopefully it works. In addition, also check the motherboard's RAM compatibility requirements to see if it does support 400mhz
Sep 17, 2008 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Ram problem
farookh, Chances are the 32MB difference is for video memory. You may be able to reduce the video memory in settings and give it back to the system. But you should check to see if it does it automatically. Good Luck, Tim
Feb 09, 2007 | VIA Itona CE, Windows CE, C3-1000, 32MB...
Gigabyte GA-6VEML Motherboard Logo
182 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Thomas F. Schneider
robert roberts
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
