Question about SanDisk Sansa c200 MP3 Player
Broken mp3 I put songs on my mp3 player and now it wont turn on and i only put on 174 sonds and it says it holds 250 so that cant be it. I need some1 help plz.
  • 8,596 Answers
The description that says it holds 250 songs is an estimate - there are zero mp3 players on the market that actually hold the number of songs that the box/product sheet advertises. Those estimates are based on low-quality songs that are approximately 2 minutes in length each. So, it sounds very reasonable that 174 songs would fill the player's memory.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 28, 2009
I got a problem with my mp3
Transfers onto the m240 can be done in 2 USB connection modes:
MTP mode: Media Transfer Protocol using software, e.g. Windows Media Player 10 or higher.
MSC mode: Mass Storage Class using Windows Explorer, looking in "My Computer" viewing the player as a removable disk.
Typically, songs put onto the player in MSC mode can not be viewed in MTP mode and the other way around.
Switching to MSC mode in the player's menu:
Look in the player under Settings Menus > USB > select MSC for using the "copy and paste" or "drag and drop" method for transfers in "My Computer".
When Auto Detect is selected, it depends on the configuration of the computer, what setup for priority has been installed.
Forcing the player into MSC mode:
1. Turn device OFF.
2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold.
3. Connect the device to the PC.
Information for the USB connection mode and how to make hidden files in XP and Vista visible, on the support site:
http://kb.sandisk.com/app/answers/detail/a_id/447
Manual for the m200 series players (readable with Adobe Reader):
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Need more help ? Don't hesitate to add a comment.
Apr 15, 2010 | SanDisk Sansa m240 MP3 Player
Cant put songs on mp3 anymore
how did you delete them?
did you delete them instantly from the file page or through the program they probably gave you with your mp3?
Also, if you removed your mp3 without clicking the "safely remove hardware" button before disconnected your mp3 with the computer, than it may have caused confussion with your hardware.
Sep 05, 2009 | Philips GOGEAR SA6045 MP3 Player
Can't see songs on GPX Mp3 player
what operating system is your computer.XP is the operating system recommended but you need windows media player 10.If you have them both you can move/sync files thru Windows Media Player(WMP) but they have to have a drm licence. If you've got Windows® 98SE, ME, or 2000 Professional. 5 just connect it, find My computer and you should see the player listed,double click and the files should be visible. I would check your friend's operating system to see what he/she used and if any problems occurred.
MTP” mode will only work, when your player is connected to Microsoft® Windows® XP and Windows® Media Player 10. The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional. 5
Aug 27, 2009 | GPX MW3837 MP3 Player
I cant listen to my songs and i cant put songs in it too help
try restarting it by holding the middle button and "Menu"
Dec 27, 2008 | Samsung YP-U3 MP3 Player
I cant put videos on my rca opal mp3 player. when i copy the video on my mp3 player, it doesnt show up when i turn my mp3 player on. my songs be there but my videos don't. if it worked for my songs, why it...
RCA Opal 4001/4002 – Transferring Videos
You will need to download the RCA Media Converter from RCA's website, and then convert the videos before they will transfer to your player.
-Tha Mp3 Doctor xxx
Dec 21, 2008 | RCA OPAL M4001 MP3 Player
Songs to my mp3 wont download
try putting them on a cd then ripping them to the hard drive then put them back on the sandisk
Jul 08, 2008 | SanDisk Sansa e250 MP3 Player
Cant add songs
It wont let me put any songs on it and it wont let me download songs!
Feb 10, 2008 | RCA OPAL M4001 MP3 Player
MY E250 IS BROKEN
This should solve it;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 17, 2007 | SanDisk Sansa e250 MP3 Player
Frozen screen
recovery mode. slide the hold switxh so that is is redish hold record keep holding record and plug into computer.
Sep 26, 2007 | SanDisk Sansa c140 MP3 Player
Sansa e130
Does the battery need replacing? My screen is cracked and it appears the battery discharges quicker than normally. For now, I check the voltage on my rechargeables before installing them so that I know they are good. Try putting one song on to see if that will play?
Aug 07, 2006 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
