Question about Hoover Vacuums
Hoover wiring the blue wire that is in the lead that runs from the hoover to the plug that goes in the wall has come loose at the hoover end and has come out of the actual hoover. i've unscrewed it but am unsure as to where the blue lead (bare copper) needs to be screwed... if you see what i mean?!!
  • 706 Answers
Hello lukeplayer,
Based on your description, ( first disconnect the plug from the wall recptacle).You will need to open up the Hoover Vacuum Body to gaion access to the internal wiring. In order to better assist you, please provide me with the specific hoover model. In general though, you will need to see where inside the Hoover that wire became detached and then rerun it. Since your cord is already broken, you may be able to strip back more of the outer cord insulation to expose the internal conductors and then route, cut to fit and reinstall them. Hope that helps.. If not, send model details,,,
Regards,
Rick
Posted on Nov 26, 2008
Vacuum shuts off and on as though it had a loose wire.
Plug in the vacuum and turn it on. If it has rollers, tilt it back or lay it on its side. Then, if it's still running, wiggle the plug wire by the plug to see if it stops and starts. Most vacuum plugs and wires get a lot of abuse from being yanked out of the wall. Buy a heavy duty plug from a hardware store and change the plug, trimming off the bad section of wire.
Mar 07, 2015 | Vacuums
Power head not working
Steve:
The terminals for the power head plug into a terminal inside the machine. You'll need to unplug the machine from the wall and open the canister to find where the terminal wires plug into. You probably need to open the lower half of the canister to find those terminal plugs. It would help if you have a multimeter. The wires actually run through the hose, so I would check the hose carefully to see if the wires have been damaged there.
Jan 06, 2013 | Hoover S3670 Bagged Canister Vacuum
Hi, I have the Hoover d14194 bagless pet vacuum..when I switched it on it worked but kept cutting out, I emptied it and cleaned the filters but now it won't even switch on.is there something I can
You could check the motor brushes, if they are worn and check for loose wire connections.
Another possibility is that there may be a break in the lead, plug it in and shake the lead, if it starts and stops you have probably found your problem with a broken lead.
Jan 01, 2013 | Vacuums
Hoover vaccum u6434-900 switch replace
2 screws remove the handle. 3 screws in the holder for the hand-held beater, and then you can see to the power switch (black with read on/off switch and two copper leads).
Remove the wire clips. Find some safe way to connect the two wire and plug in/out the vac quickly to see if the motor runs. If so, then the switch is bad. Squeeze the ends and push it through to remove.
I found a cheap replacement online from. http://www.vacpartswarehouse.com/Hoover-On-Off-Switch-p/28161075.htm
I'm not associated with them, I just found them quickly and the part quickly.
I love the vac, so it's worth a few buck to fix it.
Nov 02, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind Tunnel Bagless cord prong loose, Vacuum shutting off. Do we have to scrap the vacuum?
Home Depot has cord plugs. Cut off your plug, strip apart the three wires, black, white, green. The new plug will have a green screw for the green ground; a silver screw for the white neutral wire and a brass or gold screw for the black or hot wire.
Connect those wires, ensure that none are touching the others, plug it in and turn it on.
Good Luck,
Gary
Jun 22, 2011 | Hoover U6630-900 WindTunnel Bagless...
Vacuum is turning on and off intermittently
Turn the vacuum ON.
Go to the plug while it is in the outlet, jiggle it and the wire going into it to see if there is a loose connection on that end.
Then go to where the wire enters the vacuum.
Jiggle that to see if that makes the vacuum stop.
If there are no problems found on either end of the wire, the next step it to open the machine and check the connections at the internal switch and the switch itself.
Let us know.
Gary
Jan 29, 2011 | Hoover Breathe Easy U5250-930 Bagged...
No power from Kirby!!
Determine if the headlight works before anything else. If the light works but the motor won't you have power thru the vac and the problem is internal possibly motor brushes... or a loose wire on the inside connecting to the switch.
If the light goes out is likely a switch or cord problem. Switches on these vacs break more often than cords. What you see on top is the switch button, not the actually internal switch, however a switch does not normally fail while the vac is running, that sounds more like a loose connection or a bad cord.
So isolate the cord. Unplug it at both ends and plug lamp ( or test meter) into the cord into the cord and gently wiggle where the plug end meets the cord. If the lamp goes on and off the issue is the cord. You can buy a replacement specific to the Kirby series and plug it in yourself. If this s does not isolate the problem, take it to a service center. Kirby is very intricate inside.
Sep 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My hoover keeps cutting off and on, now it doesn't even come on. I have checked the fuse its ok and i can't cheak the wireing,the plug is moulded into the socket.
Chances are your cord was damaged inside the insulation and over time it finally opened. That would cause the cac to not operate any more. If you have access to or one of your friends has a multimeter then you can check the wiring by using that meter in the OHM mode... and placing one lead on each of the two plug terminals at the end of your cord ( not plugged into power of course ) and put the vac switch on.. you should not see an open circuit and read something in the range of 10's of ohms to 100's of ohms ...depending on what path it takes.. ( meaning that with the switch on.. you should be measuring resistance through the motor windings and/or light bulb ..if it has one... That would be a quick test of your wiring integrity... Hope that helps..
Aug 21, 2008 | Hoover Vacuums
Got a numatic henry (green colour) There is a loose wire in plug, but can't open plug to fix. how do i? Thankyou
Hi.
Very simple this one.
The plug is molded type this kind of plug is sealed so you cant make any repairs internally other than change the fuse.
You will need to cut plug off & fit A new 13amp plug.
There are only 2 wires to reconect to new plug these are
BROWN to L
BLUE to N.
& thats it simple.
Aug 01, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Carpet Beater for Central Vac
Some of these types of hoses, if there is a male plug on the end that goes into the wall outlet, could be that one side of it is fused and will have to be replaced. When something happens like a short or a bad brush roll stall, this fuse will open up. If you supplied the model number I may habe been able to look it up and see. But if the hose end cuff comes off, then you can check it with an ohm meter to see if one side is open or not.
Mar 14, 2008 | Vacuums
Vacuums Logo
116 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
