Question about Dishwashers
Water remains in the bottom of the dishwasher after a wash cycle. We just put in a new disposal - works great! Hose is connected inthe correct place and seems to be free of gunk.
  • 706 Answers
Hello sschneid,
New disposals have a knockout plug at the point of entry for the dishwasher, I assume you knew that and removed it. If not, then detach the dishwasher drain hose from the disposal and take off the hose adapter from the body of the disposal assembly.. with power disabled.. use a screwdriver to push the knockout plug out and remove it from the disposal grind compartment. Manufacturers leave that in there for peopel who need a disposal but don't have a dishwasher. Get back to me if that is not the solution and I wil help you resolve it..
Regards,
Rick
Posted on Nov 26, 2008
Bosch SL1501B dishwasher doesn't drain water after the washing cycle. Also with new drain pump. What else could it be?
Check the following.
1. The drain hose has to be discharging at a high enough point to prevent water flowing back into the machine.
2. Make sure your drain hose is not twisted or kinked.
3 . Make sure your drain line is not blocked push a flexible hose down it to dislodge any fat/debris
4.If your drain line discharges into a shared drain with another appliance i.e. garbage disposal make sure it is not blocked.
5. You may have a blockage at the inlet to the pump which would slow down the pumping rate,
Since you mentioned the mushroom shaped float allowing the washer to empty this may be defective.
See the link attached.
Hope this helps.
Crofter
Bosch Dishwasher Does Not Drain
Apr 30, 2015 | Bosch Dishwashers
Why doesn't the water draincompletely after the dishwasher cycles?
It drains as part of a cycle as does the wash and rinse cycles.
Most will drain through a hose into a garbage disposal connection. First I would check the grate inside the bottom of the dishwasher for debris them in the disposal. That issue will slow down the water from draining and timing out the cycle leaving water inside. The water when draining from the dishwasher into the disposal should be seen from above flowing out rather fast if correct. If not? The hose from dishwasher to disposal also might be clogged. This is fairly typical issue for dishwashers, when the dishes are not Cleaned beforehand.
Jan 02, 2015 | Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
I installed a new food grinder under the sink. I also replaced the dried out rubber hoses that connect the food grinder to the dishwasher. But no matter what program I use, the dishwasher refuses to drain...
Check to make sure you removed the plug inside the garbage disposal inlet where the dishwasher drain hose connects. This is a common mistake installers make when installing a new garbage disposal. Make sure the power the the disposal is secured and remove the drain hose. Place your finger inside the inlet on the side of the disposal. The opening should be clear. If not, you simply need to insert a flat blade scewdriver through the inlet connection and tap out the plug with a hammer. The plug will pop out inside the disposal, so you will need to reach inside and retrieve it before attempting to use it. Once the plug is removed, reinstall the drain line and test operate your dishwasher by starting a cycle. Once the dishwasher fills and begins the wash cycle, press the STOP/CANCEL button to initiate a drain cycle. Your dishwasher should drain with no problems. If you have any questions, please post back and let me know. I hope this helps you.
Nov 19, 2010 | Whirlpool Dishwashers
The water won't drain from the bottom of the dishwasher after running a washing cycle
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE GSD4920Z dishwasher. Problem is that it does not drain completely at the end of the cycle--about an inch of water remains. After checking for clogs, etc, we followed a troubleshooting procedure which...
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | GE 24 in. GSD4920Z Built-in Dishwasher
Water left in compartment
You need to elevate your dishwasher drain hose under the sink. The water going down your disposal side is running down the hose into the dishwasher.
Nov 05, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Water remains in drain after cycle is completed. Odor remains in unit before loading is complete (a day or two) before another wash...Normal?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 31, 2009 | Bosch Dishwashers
Water does not drain after the wash/rinse/and dry cycle
You don't list the make and model of the dishwasher, but generally,when an older dishwasher is not fully draining and the remaining water is not clean, the wash pump motor is failing.
But first check the drain hose from the base of the dishwasher clear to the drain. Make sure the hose is not obstructed. If that hose connects to a disposal, check closely the drain pipe on the disposal.
Good Luck!
May 05, 2009 | Dishwashers
My water is not draining from my dishwasher. it has 2 inches of water in the bottom after my wash cycle. it is even throughout the bottom, so my dishwasher is balanced. This is a brand new washer.
If the drain line is connected to a disposer, check to make sure the plug has been removed from the disposer. (typically, the plastic plug inside the tube where the drain hose connects onto disposer needs to be knocked out) If this OK, look for a kinked drain hose.
Sep 01, 2008 | KitchenAid Dishwashers
Open Questions:
Dishwashers Logo
268 people viewed this question
Top Dishwashers Experts
