Question about Honeywell Programmable Thermostat Heater
New batteries ...display not working
Okay I thought I would be helpful today as the wifey when I noticed that our battery light was blinking on our honeywell thermostat. So I went to town and purchased some new batteries and came home and put them in. As soon as I put them in... the LED or LCD (or whatever it is) display went blank and the thermostat would not work. I was talking to my son and he said, "see if there is a reset button"...well didn't find that but did notice when I took a kitchen table knife and put it in between the two batteries the display came back on and it would work, but as soon as I take it away it is blank again. connection problem with the batteries? I am sure hubby will know , but I am just wondering. Thank you!
  • hsb0 Nov 26, 2008
    Thank you. I am sure that will work!
  • 27 Answers
Remove the batteries and pull the metal tabs at each end stretching out a little the reinstall the batteries
Posted on Nov 26, 2008
Dyson DC35 doesn't work. when I press power button, only green blinking light is showen.
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC35 is currently displaying a slow flashing light when you pull the trigger. In order to determine what's causing the issue, our experts would need to talk you through some simple diagnostic checks when you have your machine easily to hand.
When it's convenient for you, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we'll also be able to confirm whether this is covered under your Dyson warranty.
We'll look forward to speaking with you.
Jul 21, 2015 | Dyson DC35 Handheld Vacuum
2000 Chevy 1500 battery light blinking, but system is charging fine? We thought maybe a bad diode so we swapped the alternator out with a used one. Light did the same, blinking battery icon on the...
batt mayb bad test for 12.6v -is it over 3yr old---must hold that charge ovanite--any points lower means its wearing--------if system chargn fine why did u swap altnator--------that lite cud mean a failn intrument cluster or computer prob---try unplugn computer cleaning thepins-then plug bac in once or mor
Oct 29, 2013 | 2000 Chevrolet Tahoe
Just bought my house and the porch light is controlled by Intermatic timer. Just noticed today that my porch is light is on constant. Replaced the battery in the timer. I was able to set the time and...
Don't forget to reset timer after replacing battery:
Copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If timer does not function after reset, then buy new timer
EJ500 is rated incandescent bulbs only
Gene
h
Oct 05, 2013 | Intermatic Inc. EJ500C Digital Wall Switch...
Battery draining overnight. Noticed today that my headlghts don'y turn off when parking brake is on. The battery is new. Any ideas?
sounds like you have a draw put a test light between the the positive post on your battery and the cable if the test light goes on then something is not turning off pull each fuse one at a time till the test light goes out when it goes out that is your bad circuit be sure to replace each fuse after you check to see if the test light goes out
Apr 10, 2012 | 2001 GMC Yukon Denali
I own a Lenovo Mini Wireless Mouse (Model number N30). It has been working fine since the last 4 months I have owned it. However, I noticed today that the small light on the top of the mouse is blinking...
It's indeed the low batteries indicator. I have a Lenovo N30 myself.
I suggest you use a good pair of rechargeable AAA batteries.
They last longer than regular alkaline.
Best regards.
Source: Lenovo N30 User's Manual. Own experience.
Feb 17, 2011 | Lenovo Mini Wireless Laser N10 Mouse
I just received product JB5413. Batteries were just purchased today. The remote is working fine, but it will not weigh. The instruction manual is minimal. I need help getting this to work.
If it's any consolation my Jobar/Ideaworks JB5413 scale has the a similar problem: will not weigh, yet the remote control functions okay. About one attempt out of ten will cause a weight display, though. Can't figure out why scale works occasionally, vs. never works. Batteries are new, and the battery compartments are free of corrosion.
Jan 15, 2011 | Jobar International Ideaworks Remote Read...
Laptop is not getting charged
you need to buy new motherboard, it is a hardware problem
if you still on the warranty, take advantage of that because i believe they going to replace the parts for free
Jun 15, 2010 | Acer Aspire 4720 Notebook
Battery low indicator comes on even after new battery installed
I also have this problem. I put freshly recharged batteries in the DX3900 and the camera starts to turn on and reads the memory card (the green LED blinks) and then I notice that the in CAPTURE mode the lens does not extend out of the body housing. The top display shows a flashing low battery warning and after approx. 15 seconds, the camera shuts off with no function.
I have determined that the camera appears to have changed its low battery sense level as I have verified that the batteries are indeed fully charged by using a volt meter. If I have the camera in a warm environment, and do not have the LCD display on (removes a major power drain) the camera can be made to work for a short while. If I select the LCD to turn on, the extra drain seems to cause the camera's battery monitor to think that the battery voltage is too low and the camera shut down. I have yet to resolve this issue.
Aug 18, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Car not starting, due to airbags blinking?
I had the same problem.air bag light blinking. Although the power window, radio, light, A/C,etc was working, I could not get it to start. I found out the charge indicator light was not coming on when key is turn to the on position. Cut a short story even shorter, The alternator died. Check your alternator, therefore not charging battery.. But first check your battery(all other features can still work with weak battery) Car can't start because not enough power in battery to turn over. That was my problem. Probably the same for you.
Mar 29, 2009 | 1997 Mazda 626
Characters & menus display incorrectly
It is a display driver issue. You can buy a new one or get it repaired ($100).
Feb 10, 2008 | Texas Instruments TI-85 Calculator
Heating & Cooling Logo
640 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
