Question about Vivitar V5000AF Slide Projector
Vivitar 5000AF is there a timing sequence for the gear set on the vivitar 5000af? a slide was stuck in the changer and it was pulled out. it sounds like stripped gears now but nothing visible as damaged , but I can not get to work???? Shawn
4 Suggested Answers
  • 412 Answers
SOURCE: Where in Canada can I
Try www.Bulbman.com. They have an amazing assortment of discontinued lamps! Good Luck !!
Posted on Feb 28, 2011
  • 412 Answers
SOURCE: I need a 24V/150W bulb
Check the list of available lamps at: www.bulbman.com !! If you have the 3-alpha (a 3-letter ANSI designation unique to each lamp design) lamp code it will be easier to find it.... Good Luck !!
Posted on Mar 01, 2011
SOURCE: I have Hanimex Rondex 120 rotary magazines. I was
I have a VIVITAR 5000 AF slide projector.
Occasionally, the slide gets stuck while operating the mechanical hand to change the slide. Most of the time it works when I push the slide carrier by hand. Very very infrequently, the projector actually throws out the slide.
I have ascertained that teh Kodak slides which are mounted on paper frames are much too thin for the mechanical hand pushing teh slide in and out. The solution is to remount teh slides on palstic frames or some how add to the thickness of the slide. I have not tried it yet , though.
Any more ideas?
MNAQUVI@yahoo.com
Posted on Jun 28, 2012
Battery that came with Vivitar Vivicam 8025 was old. Now it is stuck in the camera and I am having a hard time getting it out. Need to remove it so I can get a new one.
If the battery has puffed up sides you may need to grab the end of the battery with needle nose pliers and pull it out.
May 16, 2017 | Vivitar Cameras
I have Hanimex Rondex 120 rotary magazines. I was told these would work in the Vivitar 5000AF. Is this true, as the slide on mine is jamming on the return?
Any more ideas?
MNAQUVI@yahoo.com
Jan 23, 2011 | Vivitar V5000AF Slide Projector
Hi! I own a vivitar slide printer. It turns on but the shutter release button does not work. No audible click. Nothing! I tried the timer button and I started getting an annoying whistling sound I could...
Hi, I just got the vivitar too, and had the exact same issue.
The unit WILL NOT FIRE unless the slide is inserted along with the little removable "film holder" frame that comes with the vivitar. Hopefully you got this with your unit. There is some sort of thickness sensor in the slide slot, so both a slide and the holder (or something of similar thickness) to get the unit to work. Mine fires with no problem now. And I found that the "high pitched whistling" goes away if you let the printer sit turned on for a while, I think it's just the flash capacitor getting used to being charged. My unit has no noise anymore. Best of luck.
Dec 12, 2010 | Vivitar Cameras
How do i turn on the flash? vivitar vivicam 5022
Make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Set this switch to the mountain position.
Also bear in mind that the flash is for still photos only, not for videos.
May 15, 2010 | Vivitar ViviCam 5022 Digital Camera
I have an old Minolta 5000Af with a quantaray 70-300 af lens on it. Is there anything to make this compatible with the new nikon d90?
In a word, no. If the Quantaray lens fits on the Minolta, then it has a Minolta mount. A lens requires a Nikon mount to fit on a Nikon D90. The two mounts are not interchangeable.
Now, if it was an ancient Quataray manual-focus lens with a T-mount adapter, then all you would need is a Nikon T-mount adapter to replace the Minolta T-mount adapter...
Mar 03, 2010 | Cameras
Can i use the Sunpak power zoom 5000AF on a Canon EOS XTi Digital camera?
According to this website, you would be safe. http://www.botzilla.com/photo/strobeVolts.html
Dec 18, 2009 | Sunpak PZ 5000AF for Canon TTL Flash
Auto focus keeps going in and out of focus
try to turn autofocus feature off or reset the settings.
Mar 05, 2009 | Vivitar 5000AF Multimedia Projector
Vivitar Instant Slide Printer
I asked a friend who has used a Land camera how to insert the film.
Jan 04, 2009 | Polaroid OneStep AutoFocus Instant Camera
Need new cycle switch
this switch is generic to other models so ask the agent for a spare
Nov 26, 2007 | Vivitar 5000AF Multimedia Projector
Vivitar V5000AF Slide Projector Logo
57 people viewed this question
Top Vivitar Office Equipment & Supplies Experts
bhargav
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Vivitar Office Equipment and Supply Expert? Answer questions, earn points and help others
