Question about Certance Electronics - Others
Quantum CL1101 Ultrium 3 tape drive with tape stuck in drive.
The above mentioned tape drive is rack mounted in a Certance case that supports 2 tape drives. We are looking for a way to manually eject the tape. Please provide as many possibilities as possible because we have tried a few that were suggested by Google searches.
thanks.
Mark
  • 30 Answers
SOURCE: Certance tape drive (Ultriulm 3) won't work
can you upload a little more info please
Posted on Jul 24, 2009
JaxPlanet
  • 922 Answers
SOURCE: ultrium tape stuck
I highly recommend that you contact Certance for assistance. Tape drives are expensive and you don't want to risk damaging it.
If you are feeling brave you could see if you can manually eject the tape.
Remove the tape drive from the chassis and look for a manual rewind screw on the bottom or back of the drive. This is provided on some drives to allow you to manually wind the tape back into the cartrige and eject it.
I hope this helps.
Posted on Aug 11, 2009
SOURCE: Certance Ultrium 2 tape drive
Bet if you check, it is not overwritting the tape (appending) on the first tape, but will overwrite the second. Check the media properties to see. If it is this, it has probably had an update when it started going south....
Same problem here, on with Symantec about it...
Posted on Jan 13, 2010
SOURCE: The tape will not eject from Tandberg LTO Ultrium
look closely on the tray,, u'll find a pin hole in it,,, just enter the saftey pin, and it will edject
Posted on Mar 23, 2010
  • 3 Answers
SOURCE: We have a HP Q1543A Ultrium Tape Drive that is not
Try here: http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=4150338&prodTypeId=12169&objectID=c00796950&printver=true
Posted on Jan 03, 2011
NEED DRIVERS FOR STD224000N
The driver for this Archive > Seagate > Certance > and finally Quantum drive was included in Windows. Try Window Device Manager > select the drive > properties > update driver > Can Windows Update select No not at this time > Install from a list... > Don't Search...> Tape Drive > try either the Standard tape drives DAT driver or a Compaq DAT. If none of those work you are probably out of luck.
Jan 07, 2011 | Certance Seagate® Scorpion 24...
LTO Ultrium 4 Drive/Lecteurs stuck in it
Check that 'Prevent Media Removal' is disabled
Check the Support Ticket Device Analysis for indications of a stuck tape
Run the L&TT*** "LTO Stuck Tape Test"
Try a normal eject operation--Make sure that you allow up to 10 minutes for completion
Perform an Emergency Unload
Reset the drive to reset the drive firmware
Use Library and Tape Tools (L&TT) to Upgrade your Firmware
***Download LTT from www.hp.com/support/tapetools
Jul 29, 2010 | HP StorageWorks Ultrium 960 Ultrium Tape...
Ultrium tape stuck
I hope this helps.
Jul 25, 2008 | Certance (CL1001-R) Ultrium Tape Drive
Quantum Superloader remove jammed tape
You have to disassemble the unit and remove the tape. Chances are it's stuck in the carousel (the round thing at the front that spins tapes and plugs them into the drive).
May 06, 2008 | Quantum ATL SuperLoader Ultrium Tape Drive
have you checked to see how much data is being backed up? Also what software are you using - it all depends on encryption
Apr 18, 2008 | Certance (CL1001-R) Ultrium Tape Drive
3M DATA CARTRIDGE -- reg
Cartridge is basically a hard disk, with several platters, contained in a hard, plastic case. The cartridge contains neither the heads nor the motor for spinning the disk; both of these items are in the drive unit.
Dec 02, 2007 | Centon Electronics Certance AL810 Ultrium...
Electronics - Others Logo
397 people viewed this question
Top Certance Electronics - Others Experts
Marvin
Marvin
Are you a Certance Electronics - Other Expert? Answer questions, earn points and help others
