Question about HP Pavilion zd8000 Notebook
Red squares though out screen
When the screen boots up there are these red boxes on the screen its difficult to describe what it really is on the screen cause its hard to see but it does fill the whole screen
  • 1 more comment
  • Anonymous Jan 18, 2009
    I had the same issue. It started with vertical lines of all primary colours 1 at first then progressing to 200 +. I started to use the VGA out on an external monitor but it had what looked like static only in the dark areas. This eventually lead to the full screen pattern of funky squares and video card crashes. Ripped the whole thing apart to find dust clogging the heat sink cooling fins. Sorry to tell you this but by the time it gets this bad the on board video card has cooked itself to death!
  • recycle it Jan 18, 2009
    Check out the post for vertical lines. I too have seen this problem; the uniform pattern of squares across the entire screen. Turns out the cooling fins were clogged with dust and the video card fried.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    restart the machine, if the monitor display is fine and you can see a "logo" or "post screen " clearly, get back to me please
    regards
  • 56 Answers
You cn jus restore the system with the restore backup cd
Posted on Jul 23, 2009
How do I change my screen to the right coler and how do I ges a full screen
maximise the screen by clicking the square at the top right hand corner by the red x box. the while holding the ctrl key click the red box to close the page. the next time you open the page it will be full screen
Apr 14, 2013 | Televison & Video
Black square on screen
Look both in the set's menu and that of a box if used; Under closed captions in either place look for a setting labeled TEXT, that is what is bringing up the black box, feature never really used much, find TEXT in either set menu or box menu if you use one, either place can cause this, not a problem just the text feature is on. Turn it off with the remote.
Dec 14, 2012 | LG 60PK540 Plasma TV
Failure to get a trully blank or black screen
Have never worked on a panasonic projector before I admit, but you get that effect when the 3 LCD panels inside a Sharp (and I assume all brands) LCD are misalligned. To get total black (LCD Projectors find this rather difficult due to the technology) the red , blue and green lcd pixels must be precisely allignend ( they are adjustable by technician and it's a fiddly job) I reckon the green panel is a touch out and it's peeking out between the red and blue squares.
Dec 12, 2009 | Panasonic ET LA780 Projector Lamp for 780...
How to arrange furniture in the inn to unlock puzzles?
Im really bad at describing things but I hope this helps xD
Oh, I though I'd mention that Im describing the DS game
Okay, First you need to have all the items for both Luke and Prof Layton.
This means that all the squares on the top screen must be filled up .
To get the characters opinion on the piece of furniture you first have to click on the furniture that you need an opinion on and then the characters name on the touch screen.Read what the character has to say and then move that piece of furniture to the other room and see what the second character has to say.
The character who has the highest opinion on the furniture should be the one to keep it.
I hope I've helped and Good Luck xD
Apr 17, 2009 | Nintendo Professor Layton & the Curious...
Screen on my Sprint HTC Touch Pro Glitches up
You need to walk in to a sprint repair center and have them change the ribbon from the sliding LCD screen. If u have the extended warranty there should be no cost. If you don't you have to pay get it repair it should not be more then $55.00 to get it repair. Or you can send it to HTC and have them repair it for you but it takes 3 weeks to get your phone back.
Mar 21, 2009 | HTC Touch Pro Smartphone
Indiana Jones The Original Adventures
The solution to the problem of the green and red squares on the floor which you have to cross over is quite simple. You just need to use the green squares to walk on the JUMP over the red squares. Simple !! Then when you get to the other side you slide the box in and this stops the spears coming out the wall which enables the other person to follow you.
Jean Lawson
Feb 15, 2009 | LucasArts Entertainment Company Lego...
Flat battery
No, you dont need to break windows. use the mechanical key that is slotted in the end of the normal electronic gizmo key to open the drivers door. It doesn't work on the boot lid even though it should so you need to energise the electric boot release from unde rthe bonnet as described elsewhere in this solution.
Dec 03, 2008 | 2000 Mercedes-Benz CLK
Error 0.14
Finally found this solution! It is a connection issue at the bottom of the phone where you would plug in the cable to hotsync your phone.
Put in your hotsync cable and wiggle it around really good and it will fix the issue. Do this with the battery out and then pop it in until you have fixed the issue. Took me a few tries as I was worried about how hard to do it, but no problem!
Nov 18, 2008 | Palm Treo 700p Smartphone
UNABLE TO CALIBRATE TOUCH SCREEN
The only possible fix is to try to clean the edges of the screen in case any particles are trapped between the screen and the case, this can confuse the touch screen.
Do this with a soft toothbrush, it will not damage the screen.
If that doesnt work then in all likelihood the screen is broken, it can be replaced but this is not trivial. There are guides on the internet on how do do this.
Dec 30, 2007 | Nintendo DS Console
T30 startup problems...
We can start with the easy stuff first. Move the memory chip to the other slot. Remove the small square plate on bottom of the laptop. You'll need a really small screw driver for this. If you have two chips, remove one and see if the laptop will boot-up.
Jun 28, 2007 | IBM ThinkPad T30 2366 Notebook
HP Pavilion zd8000 Notebook Logo
1,301 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
