Question about Toshiba e-Studio 350 Copier
What steps to take after installing a hard drive on a toshiba 350
I had a F100 code on a tosiba e-studio 350 machine. i purchased a new hard drive and installed it. what are the next steps do i need to do in order to get the machine to ready?
  • Anonymous Dec 22, 2008
    I have a Toshiba E-Studio 450 & E-Studio 352 with same problem.
  • Toshiba Master
  • 643 Answers
After replace new hdd, u need to performs following:
Update of HDD program data and UI data.
1) Create partitions. (In case of using the download jig, this is not necessary.)
While pressing [3] and [CLEAR] button, turn the power ON.
When "Firmware Version Up Mode" appears on the LCD, key in [3] and press the [START]
button.
2) Format the HDD. (Setting Mode (08-690: 2))
3) Update with the download jig or USB storage.
4) Format the HDD. (Setting Mode (08-690: 2))
* When the FAX unit (GD-1150) is installed.
Start up with the FAX Clearing Mode (1*)
Perform the 1*-100 (FAX Set Up), 1*-102 (Clearing the image data) of the FAX Clearing Mode.
Posted on Feb 13, 2009
  • karwan
    karwan Nov 09, 2013
    Thank you for your help
Tosiba st 181- install new catreg but blinker
With the machine OFF, Press the 6 key and START and power it on. When it beeps, release the keys. A menu should appear that lets you select which items you want to reset.
Sep 30, 2013 | Toshiba e-Studio 350 Copier
MY TOSHIBA E STUDIO 451c HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
That code error meaning that you have a problem with HHD
1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt).
If it don't wok you mast replace your HHD with a new one from Toshiba.
Aug 11, 2012 | Toshiba E-Studio 3511 Color Copier
Service Required Error code F100. What do we need to do?
F100 indicatest HDD failure...
The best way to solve it is to replace a new HDD & update firmware~~~
Oct 07, 2010 | Toshiba e-Studio 350 Copier
How easy is it too fix an F100 problem on a Toshiba E Studio 3511
f100 indicates hardrive problems.
power off machine,
power back on while holding down 0 & 8 on number keypad until beep is heard,
enter 690 on number keypad,
press start,
enter 2 on number keypad,
press yes on display and wait for machine to ask for reboot.
be patient may take a while and if it doesnt work could be hard drive failure.
if it is the hard drive it could also mean updating firmware on hard drive and machine.
Feb 10, 2010 | Toshiba E-Studio 3511 Color Copier
I have troubles with a printer eSutudio4511. Code
f100 is a hard drive formatting error
[F100] HDD format error
(1) Check if the HDD is mounted.
(2) Check if the specified HDD is mounted.
(3) Check if the connector pins of the HDD are bent.
(4) Check if the connectors CN116, CN132 on the SYS board is disconnected.
(5) Replace the harness.
(6) Format the HDD. (Key in "2" at 08-690.)
(7) Replace the HDD.
(8) Replace the SYS board.
step 6 is turning the copier on while holding 0 and 8 til it beeps type 690 and hit start, this will format your hard drive, more than likely it is bad physically but you may get lucky
Jul 02, 2009 | Toshiba e-STUDIO 4511 Printer
Service manual
u can try here put your query here like need service manual copier Toshiba e studio 353 and search u get best result for  tosiba service  manual //technologysearchengine.org/
Apr 04, 2009 | Toshiba e-Studio 350 Copier
Hard Drive error No. F105
F105 is "other HDD error" . Start the copier holding 0 and 8, it goes in a test mode, then punch 690 and presss start key. Restart the copier. If does not work you might have to replace the HDD and reinstall the firmware. Let me know.
Dec 30, 2007 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 350 Copier Logo
621 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
