Question about Lantronix MPS 1-T-02 (MPS1-T-02) Print Server
Print server problems
I have an MPS1-T Lantronix Micro Print Server attached to a Microline 520 printer. The printer started printing very slow so I had the head gap adjusted, tested the cat5 line and finally I swapped the print server with another one in the office. When I did this, the printer then printed at normal speed. Does the print server need to be replaced or is there a configuration setting that needs to be reset?
  • mazruls Nov 16, 2007
    I cannot ping to the printer. suspected the ip need to reconfigure. my question is, how to reconfigure the printer?
Why my 520 does not print datas?
To determine the cause of the issue, please do the steps indicated below.
  1. Load a few sheets of plain paper in the product.
  2. Press the adjust.10.3.1.jpg Menu button.
  3. Press adjust.10.3.2.jpg or adjust.10.3.3.jpg to select Maintenance, then press OK.
  4. Press adjust.10.3.2.jpg or adjust.10.3.5.jpg to select Nozzle Check.
  5. Press the adjust.10.3.6.jpg Color button.
  6. Check the printed pattern to see if there are gaps in the lines.
  7. Do one of the following:
    • If there are no gaps, the print head is clean. Press 1 to select Finish.
    • If there are gaps or the pattern is faint, press 2 to select Head Cleaning.
  8. Follow the instructions on the screen to clean the print head, check the nozzles, and repeat the process as necessary.
If you don't see any improvement after cleaning the print head up to 4 times, turn off the product and wait at least 6 hours. Then try cleaning the print head again. If quality still does not improve, one of the ink cartridges may be old or damaged and needs to be replaced.
Sep 23, 2014 | Epson Workforce 520 Printer
I have a OKI Microline 590 Matrix Printer at my store. When we used to hit Utility it would print decently. The ink would be on the lighter side but it was legible. Recently someone came in to change the...
Re-install the printer ribbon. It's probably slipping or dragging on the head mechanism, and the printer synchronization control is slowing everything down to compensate.
Mar 08, 2011 | OKI MICROLINE 590 Matrix Printer
I have an alarm light onthe display, printer does not want to print?
I have an alarm light onthe display, printer does Problem with the OKI MICROLINE 520 Matrix Printer
Dec 08, 2010 | OKI MICROLINE 520 Matrix Printer
How to printer test page a oki 520
Go to Start / printers and faxes / Right click on print icon / properties / print test page.
Feb 17, 2010 | OKI MICROLINE 520 Matrix Printer
Oki Microline 520 printing slow
Your printhead alignment is out thats why it prints slow
Jul 17, 2008 | OKI MICROLINE 520 Matrix Printer
OKI 520 ELITE
Kindly check the DPI settings . May be more DPI this time.
Best Regards
Rafique
Feb 19, 2008 | OKI MICROLINE 520 Matrix Printer
Oki microline 590 elite
What driver are you using for this printer? Try loading a Epson LQ1050 driver and try again.
Dezzi
Dec 12, 2007 | OKI MICROLINE 520 Matrix Printer
Printer head adjustments
if you take the cover off on the left or right on the bar the bar where the carriage and head ride, there is a tab that will adjust the head gap, be careful if you get it 2 tight you my damage the print head
also I've see this be a bad head, pins not fireing all the way out.
Nov 20, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 420
you are correct, you need a new print head OR adjust the head gap on the carriage
Sep 13, 2007 | OKI MICROLINE 520 Matrix Printer
Lantronix MPS 1-T-02 (MPS1-T-02) Print Server Logo
75 people viewed this question
Top Lantronix Computers & Internet Experts
David Gust
Unlockingcom
saqi iqra
saqi iqra
Level 1 Expert
Are you a Lantronix Computer and Internet Expert? Answer questions, earn points and help others
