Question about Ovens
How to use de oven?
I got a stove SF385PEWW1, but i have no idea of how to turn on the Oven.
I don't have the manuals so, please help!!!
Actually, is disconnected, because when is connected it makes a sound all the time.
  • reysol_47 Dec 25, 2008
    oven dont work , ''door loçked'' display on the LCD sceen .
  • 291 Answers
Go here to download the one you need / larry
Posted on Nov 26, 2008
Oven dont work , LCD dispkay dor locked ?
Posted on Dec 25, 2008
    LCD display "'door locked"' oven dont wonk ???
My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to or your local parts house and install in reverse
Aug 20, 2012 | Ovens
Kenmore Oven and stove not igniting
If both top and oven are not igniting, then most likely you need an ignitor board. I should be located behind the left side of the console as you are looking from the front of the stove. I will look it up to be sure. There should be a tech sheet on the back panel of the stove to help in checking the boards.
Dec 02, 2007 | Ovens
Hi. I've moved to a new home with a Stoves 720EF oven. I was find last week but now I cant make it work at all. I think it is on automatic but I dont know how to turn that off and don't even know...
If the oven is on automatic, a small 'A' will appear in the clock window. To remove this press the second and third buttons from the left simultaneously.
If you need more information, supply an email address and I will send you a pdf copy of the handbook.
May 07, 2011 | Stoves 720EF Electric Double Oven
I need an instruction manual for a stoves heritage 720EF oven
I have just uploaded a scanned copy of the stoves 720- EF manual to the link below.
Requires the free Adobe Acrobat Reader or similar software to view the manual which most computers already have. The stoves ef720 manual file below is full and free of charge
Jun 02, 2009 | Stoves 720EF Electric Double Oven
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Apr 22, 2009 | Stoves Premier 600EMa Electric Single Oven
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Feb 22, 2009 | Stoves 720EF Electric Double Oven
Cant work oven!
I have the Stoves 720EF manual stored on the BT Digital Vault which might help. If you want a copy of it, supply an email address and I will give it access.
Also someone else has said that if you speak to Stoves nicely they may be able to send an electronic version of the manual instead of the paper copy.
Nov 27, 2008 | Stoves 720EF Electric Double Oven
Oven doesn't work.
HI. thanks for your question. i would replace the 2. 30 amp fuses in the stove. try that. if not repaired. check the timer. it must be set to MANUAL, for the oven to work, check that.thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | Ovens
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
139 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
