Question about Canon NP 6545 Copier
Error - E401
When I make one copy on the copier, I get an E401 Error stating "switch the power off and on again."
  • Wanda Jackson Jan 22, 2007
    I have found that the error deals with the automatic document feeder (ADF).
  • 31 Answers
E401 on a 6545 is the RDF (reversing doc feeder) pick up motor or pick up sensor problem. Does the rdf attempt to pick up the original or do you get the error as soon as you press start? Are you aware of how to remove all the rdf covers? The pick up motor has a timing wheel & sensor that need to be periodically cleaned.
Posted on Mar 29, 2007
Ricoh 7500 photo copier Error SC 552 how to reset it ?
Yellow cancel
107
Hold down red cancel
Select system/copy sp
On keypad type in 7807#
Tap execute On the screen
Switch machine of and on again
Machine should be good to use, unless you have a actual problem then the machine will go back to error state.
May 15, 2016 | Ricoh Office Equipment & Supplies
Clc color copier error code E061-0321
Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
1) A solid black copy means laser is defective.
2) A white copy means you should check the Primary corona and HVT.
3) A good copy means you should check the Potential sensor PCB.
Dec 01, 2012 | Canon CLC 4000 Copier
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
Error code
Owners manual states "Turn the power off, and then on. If the message appears again, contact your sales or service representative"
If you need a copy of the owner's manual, go to...
http://ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/p610n/p610nen.htm
Aug 14, 2009 | Ricoh Aficio AP610N Laser Printer
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
Canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
Dynex DX-E401 Router setup
Here is the manual, and it states that to get into the router you use admin as the user name and password is blank. I would suggest that you reset the router. The reset button is on the back next to the power connector. Use a paper clip and push the reset button in for about 30 seconds till the lights flash. Then you should be able to log into the setup page and set it up .
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Installation%20Guide.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 14, 2008 | Dynex DX-E401 Router
Please help
E401 RDF Pickup motor or pickup sensor problem, try to clean the sensor and reset the error code in *4* ERROR clear.
Jul 08, 2008 | Canon NP 6551 Black and White Copier
Minolta CF900 error C0660
There should be a lamp regulator PCB check the fuse on it. Also, if you move the scanner out of HP will it find HP again? Also, how offten does it show up scines the last time?
Feb 20, 2008 | Office Equipment & Supplies
Canon NP 6545 Copier Logo
148 people viewed this question
old marine
old marine
