Question about Dryers
Bosch Dryer. LarryB, Have you been able, or are you able to read my series of posts? Do you need me to re-type or repost all that has been said?? Best Regards: cddiable@gmail.com
    Sergeant:
    Champion:
  • 291 Answers
Sorry but i haven't seen the post / repost or contact me.
Larry
Posted on Nov 26, 2008
  • 1 more comment
  • Larry Youngblood
    Larry Youngblood Nov 26, 2008
    was thinking ,,,, do you use dryer sheets in your dryer / if so check and see if one maybe blocking your air vent on the back inside dryer / if so that can cause your problem too and alot of people will over look it.
  • Larry Youngblood
    everything i can think of without having my head stuck in it is a dryer sheet inside dryer is blocking air, the air duct on the port the filer sets in is stopped, the sensor is bad or the blower is part way restricted / sorry i can't help from here but if i was there i would find your problem.
    thanks
    larry
  • Larry Youngblood
    Shotgunthera please read my comments / larry
Bosch 500 series new dryer has locked up. Key showing on panel, door opens, but you press every button and get the same beep.
Hi dear.
Regarding your information, I would say Child lock has been activated. I do not know what model or serial number of your dryer but you need to refer your machine's user manual or contact Bosch for deactivate child lock. I hope that helps. Thanks.
Jan 22, 2016 | Bosch Vision 500 Series Front-Load Washing...
No power
Almost certainly it's the fuseable link in the rear of the dryer. It's about a $15 part, and very easy to check and change. If you take the rear cover off its a small white part with two wits of the same color connected to it, and it's on the blower housing. It should have continuity if you check it. Make sure that you disconnect one of the series to get an accurate reading of continuity. If it doesn't have continuity, it needs to be replaced.
I’m happy to assist further over the phone at https://www.6ya.com/expert/thomas_d43b1a2c941966d4
Jun 08, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Vision 300 series type WNB T80 - The dryer stops every ten minutes. I have to keep turning the machine back on. I have cleaned the lint filter (vacuumed out the lint filter area) and replaced the...
Do you use dryer sheets? The chemical in dryer sheets seal up the little holes in the lint filters. To test, take the lint filter to the sink and see if it holds water. If it does, give it a good scrub and toss out the dryer sheets.
Oct 29, 2013 | Bosch Dryers
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hi i need to replace my lint filter in my nexxt 800 series gas dryer pls advice as to where i can buy it from.
You should be able to buy it directly from Bosch. Try this link.
eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodha.htm?menuid=0000009000">http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodha.htm?menuid=0000009000
Type in your model number and a parts list and diagram will be available to you. They also provide a 1-800 number to call and order parts.
I have ordered parts directly from Bosch in the past and received them in a couple days.
Jan 12, 2011 | Bosch Dryers
I have a Bosch Nexxt 500 series dryer. Today I was drying my clothes and half way through the dry the machine just stopped spinning. I press start and it just makes a clicking sound but it doesn't spin....
Hello, Welcome to FixYa. There are a couple of scenarios which may prevent the dryer from starting with Bosch, but based on your post it is most likely the emergency shut off/belt switch. It is located by the motor and in the event of too heavy a load or a broken belt it shuts the unit down & prevents any restart...until it is repaired or reset. To save time and back and forth dialog, I`ll mention what to do about it. **Unplug the dryer before attempting any repair tips suggested here please...safety first** This will require you to remove the back panel. Once you've remove the rear panel, It is located next to the belt pulley and all you need to do is push it to the right ( from the back ) Let me know if you require further assistance to do this. Keep me posted how you make out or if anything is not clear. I'm presently on my iphone, but I can post more info with pictures to guide you if necessary...but please let me know. Thanks for choosing FixYa and good luck. Regards, Macmarkus :)
Dec 20, 2010 | Bosch Nexxt 500 Dryer
Is it possible to reverse the doors on a Bosch Nexxt 500 series dryer? If yes, does it require a kit from Bosch?
yes ,it is possible,you don't require a kit from bosch,however,you will need to disassemble the machine.if you are not confident,get someone who is.
Oct 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Dryer Struggles to Start Tumbling WTA3510 UC/13
Hi again Thomas,
Thank you for your concern. And no, I did not loose my account. It is just the way the system goes. As coldhourz has posted, I have done multiple repost but for some reason, you could not view any of them.
I have emailed the admins of the status of your post/problem. It is just that the wheels do grind a bit slowly. With your indulgence, may I suggest that we leave things as they are and just not to please accept any new solutions. I would expect that you would receive an email detailing how to go about accepting my solution.
Pls bear with us as things are being attended to even now as I respond to you. This much I know as I received an email in response to my calling the admin's attention. Again, might be some more delay(s) but what is important is that you know I have not abandoned your problem with just a single post.
Again, thanks. The FixYa rating would be secondary as your acceptance is more important.
Dec 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch washer/dryer
I also have the same washer and same problem, and it is not due to clogged filters nor due to low pressure!
Any solutions so far?
I wish I had read these posts before buying it. :(
Mar 27, 2008 | Washing Machines
Dryers Logo
22 people viewed this question
Top Dryers Experts
Marvin
Marvin
