Question about GE JVM1410 Microwave Oven
Jvm1440bd Microwave The Problem Just Started. When The Microwave Is Started A Noise Has Developed That Sound Like A Piece Of Tin Vibrating. I Have Removed Vent Cap And When I Started Start The Fan Without Starting Microwave There Is No Noise, So Fan Works Properly. This Ony Happens When The Microwave Is Cooking.
  • brian ward Jan 30, 2007
    After Listing To The Stirrer Motor I Believe The Rattling Is Coming From In The Unit. Is There High Voltage On This Item Or Is It (2-4) Screws And The Plug Removal. Reverse Procedure To Replace.
    Thanks
  • wally888 Feb 20, 2008
    Checked all motors/bearings/took apart=no explanation for gravel like noise except magnatron? Possible? Works fine, just very noisy.
    I have new magnatron, just want advice if I should replace?
  • GE Master
  • 9,156 Answers
I thought I had answered this, but maybe the reply didn't post... Vent cap? Could you be more specific about what you tried and what the noise is like - where it seems to be coming from? It looks like on some of these models, the high-voltage section emits some interference which some people are blocking with a foil or metal shield. If they do that, they should definitely insulate it to prevent shorts. Another cause of vibration on these models is a fault in the stirrer located above the cover on the ceiling inside the cooking cavity. Feel free to post back so we can help further.
Posted on Jan 21, 2007
GE Microwave model JVM1440BD operates but does not heat
On most occasions, it is magnetron. If you on your oven and hear an humming noise, that usually confirms magnetron problem.
You could see how to test magnetron
http://www.gallawa.com/microtech/mag_test.html
Let me know, once you test this.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 11, 2011 | GE JVM1410 Microwave Oven
I have a Corningware MW-A-10 Microwave Browner which I have never used - could I use it in a conventional / thermofan oven?
No. The bottom of this utensil is coated in tin oxide. It is not recommended for use in any appliance other than a microwave. Tin oxide (SnO) is flammable and particles may contaminate your food. It is suggested that you use the MW-A-10 only in the microwave, or look for a different CorningWare piece that is not in the MW series.
Oct 07, 2010 | Microwave Ovens
When started,light& turntable operate normally,but no heating by microwave. Transformer normally sounds smooth,but now makes rattle or vibrating noise,like something is loose.
Check the door safety intertlock micro switch for proper behavior. If it is faulty, the oven will think the door is open and will not turn on the magnatron.
Sep 22, 2010 | Panasonic NN-C980 Convection/Microwave...
I have a 220 Advantium. I love it and it is 8 years old. When I tried to cook in it today it made a louder vibrating noise, almost like a grinding sound. Not sure that it was cooking because I stopped it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 01, 2010 | Westpoint TV-201 Microwave Oven
This is a Microwave GE Spacemaker over the range model JVM1428BHC01 The RangeHood functionality seems to have a constant air flow. It started to make a noise like an electric motor that rattles,...
this sounds more like a loose winding in the main coil to me,,if its humming? the noise is becouse steel core is vibrating,,,if this is so then the coil wont last very long,,,and it cant be fixed! all you can do is fit a new coil,,,,and thats not worth the cost!! go for a new unit,,,
Aug 08, 2010 | Microwave Ovens
I've a Sharp R-953. convection+ microwave makes a lot of noise
check the fan blade on convection, may be loose.
Oct 30, 2009 | Sharp Microwave Ovens
Loud noise like tray vibrating. does not cook.
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # orr your data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven Model JVM1440BD: turntable doesn't work. When we press start, turntable make semi-loud noise while oven is cooking, but it does not turn. We can stop noise by pressing...
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
GE JVM1410 Microwave Oven Logo
210 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
