Question about Kenmore HE2 Plus Front Load Washer
WASHER HAS F1 ERROR CODE - Kenmore HE2 Plus Front Load Washer
  • 2 more comments
  • queeniebee Apr 26, 2009
    My kenmore H2 has F1 error code what does that mean how do i fix it ?
  • Anonymous May 26, 2009
    where is the button that you need to push once the front panel is off?
  • queeniebee May 11, 2010
    kenmore HE2 plus ?
  • Barry Coates
    Barry Coates May 11, 2010
    What make and model is your washer?
The f1 code turned into a f21 code. if you take off the front panel of the washer the manuel is in there it tells you how to reset it by pushing 4secs, releasing 4 secs for three times. To fix the F21 code unscrew the white drain after taking the front panel off and clean the drain. it will be cloged with lint, coins, bobby pins and whatever else can fit in there. LOL 10 minutes and it will be fixed like mine was, hopefully.
Posted on Apr 27, 2009
Take off the bottom front panel under the door, 3 screws hold it on. Pull off the white cover over the pump. I pulled out 4 screws, 4 pennies, 2 quarters, and a bunch of black stuff. Fixed the f1 error. Yeah.
Posted on Apr 22, 2011
Another way to trouble shoot the F21 code is to check around the rim of the washer between the rubber seal and the washer. if anything like a baby sock etc. gets lodged in there it will clog the drain. hope this helps, it fixed ours.
Posted on Jan 09, 2010
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Getting an F1 error code on Kenmore Oasis HE top Loader washer
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Posted on Sep 11, 2010
  • 1382 Answers
SOURCE: washer stops error code F1
Check to see if the screens for your hot and cold water connections are plugged with grit.Or else the problem might be due to factory defect in the control circuit board of this washer. You have to replace the board.
Thank you !!
Posted on Jul 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error code F1 on kemore Oasis washer
Posted on Sep 16, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    What does code F1 mean for a Kenmore Elite Oasis model 27032?
    Here is a link to some good information on your error code. This should explain the error code you have.
    http://www.theworldofwashers.com/2009/03/reader-mail-f1-error-code-on-kenmore.html
    Nov 21, 2010 | Kenmore 27032
    What does F1 code mean
    A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
    Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
    Get appliance parts at http://parts.fixitnow.com
    Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
    Washer stops error code F1
    Thank you !!
    Jul 24, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
    F1 error code
    check the FixYa website for other solutions for your model, look for one with 29 postings........
    Feb 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio top loading washer F1 Error
    F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
    Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error code on Kenmore Oasis He
    I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
    May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
    Whirlpool Cabrio Washer Error message code F1
    f1 code means the main control needs to be replaced. pretty common repair
    Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Kenmore HE2 Plus Front Load Washer Logo
    2,507 people viewed this question
    Ron Lankford
    Archaeology
    Archaeology
    reliableservice
