Indesit 24 in. D63 Free-standing Dishwasher
Problem for Indesit 24 in. D63 Free-standing Dishwasher
My dishwasher keeps tripping my
By shellramsay on Nov 26, 2008
my dishwasher keeps tripping my electricity as soon as i plug it in i dont want to fork out loads of money on a repair man if i dont have too can anyone help read loads of comments but dont no what the element looks like
Same Problem
Feb 24, 2009
-   As soon as i switch on the dishwasher the trip switch in the fuse box comes down and all the plug sockets in the house fail.-   Guest
Solution #1
posted on Jul 07, 2009
Not Rated)
Techie Decy
Rank: Apprentice
Rating: 0%, 0 votes
I had a similar problem with my Indesit D63. The problem was caused when someone (ahem!) left the kitchen sink plug in. The diswasher waste is plumbed just above the sink's U-bend. This created a vaccuum preventing the dishwasher from pumping out the waste water. Eventually RCD tripped on the main fuse panel. Retrying with any other programs had the same effect.
What had happened was that the water reached the overfill "gun tower" - a plastic water level meter behind the lower arm slightly larger than a bottle cork. I guess this is a safety cut out to avoid flooding the kitchen.
I returned the next day and after doing some research, checked the water level which was just beneath the tower so I switched to soak, setting number 6 on the dial, ensured sink was unplugged and switched on. The washer stayed alive and completely drained in a few minutes. My guess is that enough of the hot water evaporated to reduce the overflow level.
My initial thoughts were that element or pump had gone. My plan was to try a cold rinse/soak, if it worked it was likely the element that had burnt out or let in water and needed replaced, if it didnt it was probably the pump. Thankfully it was neither.
DMPM
Was this helpful?
Yes
No
Solution #2
posted on Jan 18, 2009
Not Rated)
HPCSolutions
Rank: Wiz
Rating: 83%, 142 votes
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
If so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
Was this helpful?
Yes
No
Solution #3
posted on Nov 26, 2008
Not Rated)
rickzilla
Rank: Guru
Rating: 88%, 450 votes
Hello shellramsay,
If your circuit breaker continues to trip when you try to operate your dishwasher from the recpetacle that you plug it in to, then buy an extension cord ( appropriately sized ) and try another receptacle that is not on the same breaker. Although notthe best approach, it will work for you. You might have to hire an electrician to upgrade the service or to dedicate a receptacle for the dishwasher only and that would cost considerably more than an extension cord. Look at the dishwasher tag to see what it is rated for in terms of Power and get an extension cord that is as short as necessary and sized for that appliance..
Regards,
Rick
Also: Please contact me if the problem is not with the service but is the dishwasher itself and I may be able to assist in diagnosing that problem ...
Was this helpful?
Yes
No
Popular Solutions for Indesit 24 in. D63
Questions and Unsolved Problems for Indesit 24 in. D63
Do you recommend Indesit 24 in. D63 Free-standing Dishwasher?
Answer
Answer
I am getting water leaking through the diswasher and have a large wet "seal" at the bottom... (More)
Answer
We have just aquired the machine with the house (no manual) The soap dispenser will not open when... (More)
Answer
My Indesit D63 won't start running. The power light comes on but then nothing. I've read other... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Indesit 24 in. D63...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1581
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
