Question about Hampton Bay 04379 Madison Avenue Ceiling Fan
MAXIMUM WATTAGE FOR FAN LIGHTS??????
Came with 3 x 40 watt candle-like bulbs, I bought some 60 watt bulbs....how can I tell if this is TOO much wattage for the fan?
  • 625 Answers
Those bulbs are candelabra type. if they came with the fixture then I wouldn't go to a higher wattage bulb. the sockets are probably bakelite and mounted with the base up so any heat off the lamps would be directed upwards. higher wattage bulbs may shorten the lifespan of the sockets. bakelite is a modified plastic. it won't melt but it will get brittle.
Posted on Aug 22, 2007
What is the maximum wattage bulb that you can put in the Langston 60" ceiling fan light kit? It comes with 2 - 13 watt CFL bulbs. They are not bright enough, so we would like to make it brighter.
Get new LED lamps with low wattage and high brightness values. Additionally, the LED bulbs last a long time and use far less electrical energy than standard bulbs.
Jan 16, 2018 | Dryers
Can I replace the 13 watt CFL bulbs in my fan light fixture with a higher watt bulb
The bulb fixture itself should tell you what the max wattage is that you can put in there but they are normally at a 60watt limit.
Feb 25, 2015 | Hampton Bay Dryers
Do you have plastic replacement shield for light bulb for GE Exhaust Hood - Model JV347 0XIAA - Serial GS867119C ?
I'm betting 60 watt is much higher than the wattage recommended generating way too much heat in the confined space under the plastic shield. There should be a sticker in the bulb compartment listing the maximum wattage recommended.
Nov 23, 2014 | Heating & Cooling
Want to know power consumption of a hpsr5410f
The HP Pavilion w1907, 19 inch Widescreen monitor, RK283AA,
uses 49 Watts in operating mode, 2 watts in sleep mode.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00916924&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3351967
The Compaq Presario SR5410F Desktop PC, has a 250 Watt power supply. (Maximum wattage rating )
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01374067&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3686678
Theoretically.
Back in the day when this computer was made, Power Supply manufacturers were 'fudging' a bit on the truth.
(HP has their Power Supply's made by another company.
Bestec, HiPro, and Delta, are three of them )
Actual wattage is more like 60 to 70 percent, of what is stated.
250 divided by 10 = 25.
25 times 6 = 150 (60 percent)
25 times 7 = 175 (70 percent)
Your Power Supply's actual maximum rated wattage, may be as low as 150 Watts!
Going with the Power Supply produces a maximum of 250 Watts;
If you are playing an intense game, or have several programs running at once, you MAY reach using 250 Watts.
Just surfing the internet? About 100 Watts.
Desktop PC plus Monitor:
1) Surfing Internet: 149 Watts, or let's just say - 150 Watts
2) Computer is maxed out running hard?
249 Watts, or let's just say 300 Watts.
Voltage times Amperage = Wattage
Wattage divided by Voltage = Amperage
Number 1 above? About the power it takes to use a 100 Watt light bulb, and a 50 Watt light bulb. (Incandescent)
Number 2? About the power it takes to run three 100 Watt light bulbs.
(Incandescent)
Regards,
joecoolvette
Apr 16, 2012 | HP SR5410F 18GHz Presario Pentium Desktop...
What kind of bulb does the vec137c-wm 1,000,000 spotlight take?
Hi daved750...
Remove the bulb and take it to your local auto parts retailer and show him the bulb, most of the bulbs that are used in the lights that you describe are available and a lot cheaper than ordering at the website of the dealer.
The bulb will be a 55 or 60 Watt HID bulb..The higher the wattage the brighter the bulb...but the less time the battery will last..
For a one million candle power bulb...it will be the 55 Watt bulb
Please take time to rate me
Sep 07, 2011 | Camping, Backpacking & Hiking
Can i use a standard light bulb in a ceiling fan?
Probably 60 watts ... 60 is pretty much the limit I see on these devices.
So, you want more light, use CFL's in your Hampton Bay. You can use as large a CFL as will physically fit into the globe, consistent with remaining below the max watt limit. CFL's put out more lumins per watt than conventional light bulbs do. (Compact Flourestent Lamps)
Find CFL at a retail store near you - hardware store, big box store. LCD are another alternative for your consideration. Find LCD at http://www.ledlightbulb.net/ ... and here http://www.google.com/products?hl=en&resnum=0&q=led+household+lighting&um=1&ie=UTF-8&ei=G36BS4rjG5WWtgf39OnhBg&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CC4QrQQwAw
There are probably a lot of other sources for these specialty lighting products. Perhaps you could see a demonstration at a lighting distributor store in your area. Be prepared for a pricy product. I thnk LCD are around $20.00 each while CFL are probably $8.00 each or more.
I hope I have helped you with your question. Thanks for your interest in FixYa.com
Feb 21, 2010 | Hampton Bay 37225 Cameron II Plus Fan
Hampton Bay Ceiling Fan Plastic Burning Smell
I think you have already figured out what the problem most likely is; 60 watt bulbs. Down-size the wattage or install 'energy saver' bulbs if they will fit the application. Instead of counting on these units for extra lighting, perhaps think about Track lighting to fill in those ares that need more but subtle light.
Good luck. :)
Apr 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton Bay 04379 Madison Avenue Ceiling Fan Logo
468 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
