Horizontal lines on picture
Recently repaired field / frame vertical stage replace vert amp IC301, C432 ,( D431 & R431 blown) set is now working,however the picture has a few horizontal lines in the centre and bottom of screen i presume i need to know how to access the service mode to do vertical alignment as the Vheight is a little out.
Does anybody know how to access the service mode on this set please help.
Thanks in advance.
  • 5,568 Answers
Can't advise on entering setup but the lines may be due to the maladjustment of the brightness control on the flyback. There will normally be two adjusters, one for focus the other for brightness.
Posted on Nov 26, 2008
My tv has a line through the centewith half o the picture at the bottom!
It is vertical stage problem .check supply voltage,and output voltage of ver ic,If it is upnormal find reason,and also resold the ver.ic .and change vert stage electrolytic filters.finaly replace vertical ic.
Aug 11, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have akai 2201 television set when i start the tv there comes a horizontal line on the screen with no sound & picture kindly gudie
IT IS VERTICAL OUTPUT SRAGE FAULTY. FIRST CHECK SUPPLY VOLTAGE 18VDC. THEN CHECK OUTPUT VOLEGE 15VDC.IT IS UPNORMAL FINALLY CHANGE VERTICAL OUTPUT IC.BEFORE CHANGING IC CHECK ALL THE COMPANENTS IN THE VERT.STAGE
Aug 02, 2010 | Akai Televison & Video
Thin horizontal line of picture
that is a vertical deflection circuit problem. try to check a 470 UF capacitor connected to the vert. yoke coil if it is open or try resoldering the nconnecrtion at the board. if not, try to replace the B+ filter of the vertical amplifier. another is try to chexk if the vertical moscillator is qworking if you know elecrtonics.
Jan 27, 2010 | iLO V27DMBX Television
Sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
Jun 18, 2008 | SansuiM1315 TV
Horizontal line on screen
The most common problem would be a bad solder joint on the vertical drive IC. It could also be a bad solder joint on the flyback transformer, as it supplies voltage to the vert. stages. If you disassemble the set, please be careful not to get shocked. Discharge the high voltage stages as a precaution.
Geno
Feb 26, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Audiovox AVT 1598
The vertical output IC or the vertical circuit is whats at fault. its all solid state and im sorry to tell ya that its not a user replaceable part. This set is probably not worth the repair it would take to get this set working again but please if you like ask a ;ocal repair shop what they thought about this problem.. Good Luck and please dont forget to rate this thread
Nov 11, 2006 | Audiovox AVT1498 TV
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
No picture
If you know how to trouble shoot solid state electronics, you should not have a problem trouble shooting this set. it sounds like a bad solder connection But these sets are not made for a consumer to repair as they are all soldered into placxe and inside a TV set is not tyhe place for a peep to br if he doesent uinderstand thongs
Sep 09, 2006 | Hitachi 32UX01S TV
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
