Question about Cobra 25 LTD 40-Channels Base CB Radio
Limited cb radio range on Kenworh t800 truck
I have poor transmiting and receiving in a kenworth T/800
  • AnyMHz.com
    AnyMHz.com May 11, 2010
    where are the antennas. are they up on the sleeper? if not. get an swr meter or have someone check the antenna.. or goto www.radiotx.com in temple, tx there a radio shop.. they do great work.
  • 170 Answers
I recall problems grounding the antenna on those kw's. May want to try a no ground antenna. Also the stock coax that comes with the truck sometimes gets broken or pinched. Go to a good shop, replace the cheap coax and grount the antennas.
Posted on Dec 28, 2008
Fuse panel on 93 kw t800
Should be under the steering wheel against the firewall. here is the layout for a 95 Kenworth T800 http://kipipo.com/kenworth-t800-fuse-box.html
Jan 02, 2018 | Cars & Trucks
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Handheld Radio Shack CB radio TRC-230 I can hear people but no one can hear me
First, lets make sure that the unit does transmit. Get a power meter and see how much power it transmits. If no power is being radiated, you need to have a technician check out the unit.
If you have power then pick a less crowded time to test out if anyone can hear you. Other people with more powerful equipments can only be a problem when you are transmitting on the same channel and both of you happen to transmit at the same time all the time. Chances are remote that this is your problem. Good luck. es
Mar 23, 2013 | Radio Communications
Take out evaporater fan for 1999 kenworth t800
Should be 4 screws holding in the plastic cover over the evaperator then another 4 screws holding the fan bracket in. Depending on the fan you may need to cut the wires then use a **** connector or marrettes to re connect with the new motor
Sep 06, 2012 | Refrigerators
My radio receives the wx stations fine, it transmits fine but it will not receive when switched to cb, I have tryed ex speaker, still nothing. mete wont move in receive mode, but when keyed the tx is over...
Here is the list just scratching the surface.
  • Bad antenna
  • Bad coax cable ......grounding externally or internally with shield.
  • Bad/poor ground for antenna..........door to body, painted parts when mounted elsewhere.
  • Antenna installed incorrectly. Nylon grommet must insulate antenna from contact with mounting bracket. Coaxial connector must have contact with bracket for grounding.
Jul 02, 2011 | Uniden Bearcat Pro PC68LTW 40-Channels...
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
My cb will transmit ok but my reception range is not very far and I have a K40 trucker antenna
location of the antenna is every thing.the other thing to check is you swr.If your swr is to high your reception will be poor
Feb 20, 2011 | Cobra 29 LTD CB Radio
I can receive well, but have limited output..can receive from drivers over 10 miles, but when I try to talk back I only have about a 1 1/2 mile range I got a new power mic, but it doesnt seem to help......
Could be poor antenna, or not high enough on the vehicle.
Also most truckers have had their radio's peaked and tuned.
If this radio is stock its only putting out 4 watts, which should still get you about 8 miles.
I do not know what the modulation and AM power POT's on the board of this radio are.
You can take it to a truck stop that has a radio shop. they can peak it usually for less then $30
Oct 20, 2009 | Magnum S9 Base CB Radio
Transmitting
its the coax. i had this same issue. i thought a bought a great strand but, it was very poor in design and it developed many breaks over time, reducing its transmitting ability. I would also check the mic wire and head connections as well. this is a problem spot at times.
Feb 25, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Can not hear people through static from radio.
no,its in the radio.i have had a lot of radios,and i have had several with just too much noise.its in the radio.i would not go by what a trucker cb shop says.contact company,or try and sell it and start over.i have had to do that also.
Feb 15, 2009 | Connex 3300 240-Channels Base CB Radio
Cobra 25 LTD 40-Channels Base CB Radio Logo
626 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
