Question about Kenmore 44103 Side by Side Refrigerator
I have a Kenmore side by side refrigerator/freezer. I am getting really slow flow from water dispensor (outside freezer side door). It takes 20 seconds to fill up a glass of water.
  • davidwright1 Nov 26, 2008
    Thank you for the response. My ice cubes are fine. I'll look at replacing the filter first and then the water valve if that doesn't resolve it.
    Sergeant:
    Champion:
  • 291 Answers
Check to see if your ice cubes are well formed or hollow / if hollow replace your filter 1st and if no good replace your water line / if cubes are large and well formed the replace your water valve to fix your water problem.
Posted on Nov 26, 2008
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
WATER WILL NOT FLOW
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Oct 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Hello, lost water in the house, now when came back on, water dispensor has a slow drip... the dispensor handle seems to be working fine... it dispenses water when pressed.. doesn't seem to stay...
If you take the bottom grill off the front of the appliance -1x Philips screw either side- under the freezer door you will see where the water pipe goes through the hinge. follow that pipe back towards the underneath of the machine and you should come across a push-fit connector.
The pipe leading through the freezer door from the connector, and blow down it, re-fit, press dispenser paddle to allow to flow. This stops the drip in 9/10 instances.
If not you may need to have someone check the water valve for slight blockage.
Jan 27, 2011 | Whirlpool Refrigerators
My kenmore refrigerator 106.56166500 quit dispensing water. Icemaker works fine. I disconnected the water line at the bottom of the front door via the quick disconnect and I get water from the supply side...
The line inside the freezer door is frozen . Turn the temp in the freezer , to warmer for a few days , and it should thaw . A dispensor heater is available , pt # WR49X10173 . Instructions come with the part .
Nov 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water from the water dispensor not flowing anymore
Do you hear the valve opening at the back of the fridge click when you push for water?
If not ....it may need to be replaced.
If you do hear a click.....the water line may be frozen in the freezer door.
Open the door wide open for a while......1 to 2 hours and occasionally try the water.....cover the freezer compartment with towels to keep the cold in that area but not the door.
Aug 17, 2009 | Whirlpool ED5FTGX Side by Side...
Water dispenser suddenly not dispensing water
Remove the bottom kick plate . Follow the plastic line about 6" and you'll find a connector . Push in on one end of the connector and at the same time , pull the line out . Close the door and press for water . If no water comes out of the disconnented line , the water valve is probably bad . If water does come out , the line inside the freezer door is frozen . If this turns out to be so , you can lower the freezer temp for maybe days , or , put the food on the door, inside the freezer , tape the light switch down ( to keep the lite off and fan running ) and tape plastic over the freezer door opening so the freezer will continue to work . Reinstall the line back into the connector by pushing the hose firmly into place . Leave the freezer door open for maybe 1 or 2 days for thawing out , going by ocassionally and pressing the water dispensor . Important : lower the freezer temperature slightly to keep line from freezing again . ONLY CHANGE THE FILTER WHEN WATER FLOW SLOWS OR ICE CUBES GET SMALL . The change filter lite comes on by the amount of times water dispensor is used and to make money for the vendor .
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispensor on freezer door does not work
usually you could have a bad water valve. the dispenser side of the valvle could be froze up. if not then there is a small micro switch above the dispenser lever.
Jun 21, 2009 | Refrigerators
Refrigerator wate leak
Usually at the bottom outside of door (near hinge) is where the waterline will become loose or crack. Otherwise, I would have to look at it.
Apr 21, 2008 | GE Profile CustomStyle PSI23NGR Side by...
Water Dispensor
The water line is frozen inside the freezer door. Open the freezer door and take a hair dryer to warm the inside of the feezer door. Check the water dispenser every 5 minutes to see if the line is unfrozen. Water line is ran from the bottom to the waterr dispense unit. Usally take 10-20 minutes to unthaw water line inside of freezer door. Good luck.
Nov 07, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Kenmore 44103 Side by Side Refrigerator Logo
185 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
