Question about Kenneth Cole KC1219 Wrist Watch
Kc1219 date adjust
Hello. How the I adjust the date on my kc1219 wristwatch?
  • 944 Answers
Contact these guys; http://www.kennethcole.com/scripts/service/contactus.asp and they should be able to help - sorry the info appears not to be available online. Hope this helps :)
Posted on Mar 25, 2007
Date will not foward but time on watch is running fine i can adjust the date but it doesnt move even though the time has advanced
the date wheel of your watch has a problem, it has to be fix by timex watch technician. or someone that is good in handling a timex module.
Jul 11, 2011 | Timex 27191 Wristwatch
Watch is missing user guide, how do I set the Honora 3ATM watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Apr 30, 2011 | Honora Watch
Cant set wrist watch
Apr 07, 2011 | Movado Juro 0605023 Wrist Watch
How to adjust the date
you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 06, 2010 | Tag Heuer 2000 WK1110.BA0317 Wristwatch
No action when I pull the stem out to adjust time
There may be more than one "out" position.
Typically there are three positions 1) home 2) 1st adjusting position, 3) 2nd adjusting position.
If you haven't got the instructions, you can get a download from their web site, (Rolex.com). You go to the bottom of the screen and there is a menu. Select "downloads" and you will see a list of downloads, choose yours.
Feb 08, 2010 | Rolex Submariner 16618 Wristwatch
How do you adjust the band on a rolex watch
Unscrew bracelet screws from the side and take out/add link. Then screw bracelet screws back.
Jan 29, 2010 | Rolex Day-Date President 118239 Wristwatch
How do I set the time on my Armitron All-Sport wristwatch
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"---compliments of Gene Lawson
Jan 21, 2010 | Armitron Two Tone Sports Watch
How do i adjust the date on my classic watch?? pull the pin and rotate cw or ccw no changes.i have an indigo classic watch. does date need to be adjusted every 30 day months? thanks
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
Jan 12, 2010 | Timex 5B841 Wristwatch
Tag Heuer date adjustment doesn't work. I pull the crown out one notch, turn it clockwise, and nothing happens. Turn in it counter clockwise, nothing happens. ???? The only way to adjust it is by adjusting...
The date change occurs at midnight, so winding it past midnight changes the date. To change it again wind the hands backward to (say) 11 O'clock) and then forward again will change the date again.
How far you need to turn it back will have to be found by experiment.
Jan 03, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
Changing the time on my wristwatch
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
Mar 08, 2009 | Armitron Two Tone Sports Watch
Kenneth Cole KC1219 Wrist Watch Logo
47 people viewed this question
Top Kenneth Cole Watches Experts
Arturs Kalnins
Arturs Kalnins
Norman Worley
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
