Question about Kitchen Ranges
E2 F3 error code, on a kenmore oven, upper heating still on
  • David Burkhart
    David Burkhart Dec 24, 2008
    E2 F3 showed on the LED display. Upper heating element would not shut off. Had to turn circuit breaker off. Turning it back on does not work either.
    Everything I'm finding is point to replacing the oven temperature sensor. But, nothing conclusive yet.
  • bambis Apr 05, 2009
    error code E2 F3 kept beeping and by the time I found the post about the upper element, it was buring cherry red and almost burnt up my casserole!! I had to go throw the breaker to turn it off. Will letting it cool down help? what needs to be replaced, can we do it ourselves or call Sears and about how much does this cost?? Any ideas??
  • 210 Answers
Replacing the temperature sensor did the trick for me and was really cheap and easy to replace.
Google your make, model ID, and "sensor" to find the right part. Then, order the best deal you can find. When it comes in, pull your stove our away from the wall. Unplug the oven to make absolutely sure there is no live power still running to it. Remove the large panel from the back of the oven. From a rear view, follow the wires that run toward the right, a little more than halfway up, buried in the insulation. This will be where your temperature sensor is. It is easy to figure out how to extract and replace it.
Once you've replaced the sensor, and before you put everything back together, plug the power cord back into the wall and turn your circuit breaker back on for a quick test to make sure the new sensor is working okay.
Please, make sure to unplug again before putting it back together. You can't be too safe. Remember, the oven runs on 220 volts, which is double the standard household voltage. And wires on the back of these ovens come a little too close to that solid-metal sheet rear cover for my comfort.
Posted on Oct 14, 2009
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to change the door switch
Hello.
Some Washer ranges are equipped with electronic displays that indicate the time of day and the oven's temperature when it's in use. The display also alerts users to error codes including PF, or power failure, and various letter and number combinations that correspond to issues ranging from electronic control malfunctions to problems with the oven door latch.
Related Searches:
F2 Faults
Washer F2 faults relate to temperature problems in the oven. In the case of the error E2-F3, F2 is the general fault code and E2 is the specific error code. An E0-F2 error indicates that the oven's temperature sensor is open; E1-F2, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E2-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in "Clean" mode.
Clear Error Code
If your oven display shows a letter/number combination, washer advises clearing the display. Press "UPPER OFF" or "LOWER OFF" on double oven models. On single oven models, press "OFF/CANCEL" to clear the display. If the code reappears, the manufacturer recommends contacting a professional service technician or contacting the Washer producer
Professional Service
The Tech Sheet included with Whirlpool ovens is meant for use by professional technicians servicing the unit. To address an E2 F3 error, a technician can check the oven's temperature sensor connection, measure the sensor's resistance and, if necessary, replace the sensor.
Thanks.
Dec 07, 2011 | Washing Machines
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Hello my oven will not turn off and it gives me an error of E2 F3
F3
(upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
mode)
Dec 11, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
I have a Kenmore Self Cleaning Electric Range and I am getting F3 and and E2 Codes. When trying to pre-heat the oven, an F3 code appears and then the oven shuts off. Sometimes while trying to pre-heat...
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Nov 09, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Oven problems
Either the oven control is bad or the element is shorted to ground.
Oct 08, 2007 | Kenmore 92022 / 92024 / 92025 / 92029...
Kitchen Ranges Logo
439 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
