Question about Sharp CD-XP7700 CD Shelf System
Music plays, but vocals are weak
Somehow my stereo has been adjusted to where you can barely hear the vocals when playing a CD, even though the instruments play loud and clear. I think that it is an equalizer problem, however, the options I see are just to hit "pop" or "rock" or "classical" to adjust it. It doesn't have individual equalizer bars to adjust. Any idea of how to fix this? Thanks!
  • 82 Answers
Check and make sure you hook up the speaker wires correctly to the stereo, they are color coded. This unit does not have manual equalizer settings.
Posted on Mar 27, 2008
SOURCE:
Am using a Samsung HT-e750W ampiflier. When i play a dvd i can hear the music but no vocal sounds
The vocals are directed to the centre channel. If this is not connected or the connection is poor then it will mute the sound of the vocals.
If you want you can select stereo mode when listening to just music. Not the surround modes. Or you can check the centre channel is working and not switched off. Some amps have the ability to switch speakers off in different modes or settings.
May 12, 2018 | Samsung Audio Players & Recorders
I use Samsung C3010. when playing music player, I don't hear any voice. I only hear the instruments. I've tried many airphones but nothing. can it be solved?
How are you obtaining the music that you play on the Samsung C3010? If you're recording the songs yourself, it sounds like you are recording one channel out of phase with the other. This phasing "effect" is how vocal eliminators work. Try playing back music from another source and see if the vocals return.
Aug 14, 2013 | Audio Players & Recorders
I have a SoundMAX Integrated Digital Audio soundcard in my Windows XP pc and in the Midi Music Syntesizer, I have the following Syenthesizer default sets in the control panel: SoundMAXGeneral MIDI and...
Ok right click on the speaker icon next to the clock and press adjust audio properties, a new window will open up with about 5 tabs on top, click on the audio tab and click volumn under sound recording and another window should open with mic, line in, stereo mix/what you hear etc now if you see stereo mix or what you hear put a check mark in the box so you can play music via the web.
But if you don't see it click on options then click properties and list of name's should appear scroll down and find stereo mix or what you hear and check the box and it should now appear next to the mic.
Hope this helps.
Jul 03, 2011 | Computers & Internet
The Graphic Equalizer pattern control is not working correctly - I can hardly hear the vocal on my CD's when playing even though I've selected vocal. Vocals are outplayed by background music.
That sounds more like a polarity, or phase problem. Make sure your speakers are hooked up correctly, with the correct colors going to (+) positive, and (-) negative. Make sure your rca connection are correct, and that every connection has a left and a right. No stereo-to-mono adapters.
Is setting to "vocal" an eq selection, or a "dolby" stereo selection?
Are you using a dolby surround stereo receiver with left, right, center, rear, etc.?? If so, try turning off any effects, or anything that would send signal to the center speaker.
Lastly, depending on what the source of your music is, it is possible if your connections or receiver settings are not correct...that the music upon playback will be out of polarity, meaning the vocal portion will cancel out. Combining left and right signal together can sometimes do this as well.
Apr 09, 2010 | Denon D-C30 Shelf System
When playing music, can here vocals sometimes.
You need to get a new sound card because the one that you have is going out.
Jun 17, 2009 | Toshiba Satellite M115-S3094 Notebook
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
Distorted voice on computer music
go compaq .com download latest sound driver for your model under help drivers area k
Oct 07, 2008 | Compaq Presario SR1050NX (DW257A) PC...
No vocals!
Maybe your headphones are pulled out halfway.
Feb 11, 2007 | SanDisk Sansa m240 MP3 Player
Sharp CD-XP7700 CD Shelf System Logo
124 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
