Question about Jet 708315BTC/JBTS - 10BT - 3 10 Benchtop Tabl JBTS - 10BT - 3 10 Benchtop Tablesaw
Pulled out motor and did not write down where wires go back and now eather it is on all the time or nothing or it throwes a breaker in the house only 4 wires and switch and reset please help.
  • 25 Answers
You'll have two wires from the motor, a black and a white. The cord wires should also be white and black. The cord black is the hot wire and that always goes in one side of the reset and out to the switch and out of the switch to the motors black. The white is a neutral from the cord and connects to the motor white. Please remeber that a black always runs thru the switch to the motor as a means of controlling the energy required to activate the motor. Be careful!
Posted on Nov 27, 2008
Compressor builds to 100 lb pressure. after a few minutes use, it comes on again to begin pressure build up. next cycle, it trips circuit breaker in house.
You didn't provide all pertinent info available to you. Lets take what we have; and, consider why your compressor is overloading the circuit breaker. Points to ponder:
  1. Not knowing the exact model (not series) I don't know what the amperage pull is for your "extreme" compressor or the circuit breaker's rating. A 25 amp compressor connected to a 25 amp breaker could be an issue. Campbell Hausfeld's support pages are crashing so I can't check the possabilites.
  2. Are you using a lightweight extension cord? The lower the rating of an extension cord the higher the amp pull on the breaker. If you eliminate the extension cord does the problem go away? Ohm's Law applies. <http://www.ohmslawcalculator.com/ohms-law-calculator>
  3. What else is on this breaker? Is there other high-amp equipment in another room (water cooler, window air-conditioner, portable electric heater, etc.) pulling from this same circuit breaker.
  4. Is the circuit breaker not performing to specification? I've seen failing breakers trip early.
    First, check the owner's manual for power requirements. Next step, use no extension cord; and, insure nothing else is pulling power on that breaker. Then, use a different breaker and see if the problem follows the compressor. If all else checks out than I'd consider binding in the compressor causing the amp pull to be too high.
    Good Luck!
Mar 29, 2015 | Campbell Hausfeld Extreme Contractor...
I put a circuit tester in my 110 normal socket throw out the house. I found all but 3 read Green. Those three read Green and Red for either Reversed polarity or open neutral. How can I fix the prob
may be either defective outlet or mis-wired. Check to see if all three are on same circuit . If so, check wiring at the breaker. may be reversed (white to earth ground and neutral, black to breaker. Open up the outlet box and pull the outlet out (carefully ,open the circuit breaker first), then check with VOM. Voltage white to bare wire(earth ground) should be 0. Black to earth should be 120V. Black to neutral (other side of socket) should be 120.
Feb 02, 2015 | Dryers
Dyson dc33 troubleshooting
i would try plugging it in at someone else's house and see what it does.
I need more info on this matter. i assume it will trip just one breaker in the breaker panel. if it is tripping more than one your breaker, your box is not wired correctly and you need to call an electrician immediately before your house burns down. is the sweeper new or used? if know for sure your wiring is ok in the house then your sweeper has a loose connection or bad motor and you need to have it fixed or throw the sweeper away. the money you loose by fixing or throwing away is a very small price compared to a fire.
Aug 29, 2014 | Vacuums
Model CKL36-IL was installed just before I purchased home in October 2005. How long is warranty? Recently had it repaired (was dirty). Repairman said it looked/sounded like compressor was about to go...
Factory parts warranty is five years all parts one year labor. Capacitor and/or fan motor has gone out and will need replaced. The breaker will throw itself off if the condition gets bad enough. Suggest not using until repaired, turn off breaker.
Jul 30, 2011 | Goodman CKL36AR36 Air Conditioner
Wired vent using 12/2 wire(house is also wired in 12/2) In fan I connected 12/2 white to white/back in fan and then black to black. Breaker keeps tripping? Did I do something wrong? Mark
Even if you use 12/2 rated wire and your house is wired in 12/2 if you pull to many What is the amp rating of your breaker that feeds this fan? If your breaker is rated at say 15 amps and your pulling 20amps from that fan you will continue to throw the breaker.
Regards, Tony
Apr 26, 2011 | Air Vent WCGB Attic Aire Window Mount Fan
It continually throws my house breaker
if it comes on and works for a while and then trips the breaker its pulling to many amps. try to put it somewhere where nothing else is plugged in and see what happens. Sometimes you can have to many things on one circuit.
Dec 17, 2010 | Patton PUH680-U Utility Heater
We are unable to get power to one specific area of the house. I did reset the circuit breaker associated with that area. Nothing works. I do not have power in that area. This is a brand new unit in a brand...
You may have arc fault breakers in this area. Be sure to unplug all devices and try to reset breaker again. Some brush type motors will not work on arc fault breakers. If this is a brand new house then call the builder back and let him get the electrician back in.
Sep 10, 2010 | Cutler Hammer Electrical Supplies
Electric oven and stovetop do not work, clock and oven light do.
Sounds like you are only getting 120 volts instead of 240 volts. Either a house electical problem or wiring in range. First go to your breaker and turn it off and on three times and give it a little extra push each time you flip it. ( You can actually flip a breaker off and on without resetting a blown breaker if you doni't push it all the way off and all the way on. If the breaker throws itself off do not reset it. You have an elecrical short in your house or range. If resetting the breaker does not work then you need to test for 240 volts coming into the range. We don't recommend you do any electical testing unless you know what you are doing with electicity. If you have 240 volts going to the range then unplug your range and remove the backing panel off the back of the range. Look for burned wiring or terminal blocks. If there is nothing obvious then you need to know how to read a wiring schematic and use a electical tester to go any farther. Let me know if this helps. Good Luck, Appliance Specialists
Dec 15, 2009 | Amana AER5715QAS Electric Kitchen Range
Throwing breaker
Throwing the MAIN BREAKER should not happen. Calculate the distance to your main box. Tell me the wire gauge or breaker amperage. Whatever you do, do not get a larger breaker! If its a breaker on this unit Its probably doa with current leak possibly. DO NOT USE fire hazzard IF SHE TRIPS!!! let me know if its your main breaker inthe house. Hopefully you dont have crappy cloth wiring.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Jet 708315BTC/JBTS - 10BT - 3 10 Benchtop Tabl JBTS - 10BT - 3 10 Benchtop Tablesaw Logo
115 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
