Want to use Dell 3115 for B/W printing without color cartridges
This machine has separate cartridges for black and each color. We are only using it to print black currently. Dell rep originally told me how change a setting on the panel to allow it to continue printing. I believe it was a change in a setting - selecting something generic instead of something specific to Dell. Now, no one there seems to know this anser.
  • 110 Answers
SOURCE: Epson R310 Non Epson Cartridge Warning
Essentially Epson should release drivers to resolve this issue. I am not sure there is a exact fix but according to recent US law paased within the last year or so, it is illegal for them to program this into there software. Call the customer relations or email them at
customerrealations@ea.epson.com
Posted on Aug 24, 2008
SOURCE: PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Posted on Feb 21, 2009
  • 26 Answers
SOURCE: Can't select to print in black and white
when you do a "file" "print" to print the form - click on "preferences" in the print menu - then select "grayscale printing" box. this may have to be done each time you go to print something new
hope you got your taxes done already
Posted on Apr 16, 2009
ariyoso
  • 145 Answers
SOURCE: How do print black only on a HP C3100
maybe you just need to check the "grayscale printing" option in the printer menu..
Posted on May 27, 2009
  • 630 Answers
SOURCE: wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Posted on Aug 22, 2009
Dell printer won't print
It may have a date code ill not allow you to print without updating/replacing the cartridge. I got rid of hy HP for the same reason.
Jun 03, 2017 | Dell AllinOne Multifunctional (v515w)...
When I print from the internet my copy prints my color comes out a different color I think it might be my black ink is off I have a dell 946 all-in-one printer.
Are you using Dell Series 5 ink cartridges?
Can you copy a document under the glass? Black & White and color? Do they look ok?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 5 black cartridge and then reseat it. I would then take out the color Dell Series 5 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges .
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 5 ink cartridge with a bad sensor. I would that these back to the place of purchase for a replacement or a refund.
Rick
Jul 27, 2011 | Dell 946 All-In-One InkJet Printer
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
Black Cartridge Not Being Used While Printing
try printing in monochrome mode or gray-scale mode, and specify that it use only the black cartridge.
another problem could be that the head have gotten dry, remove the cartridge, get a soft cotton towel, wet it with a little bit of water, put the head of the cartridge (where the ink comes out from) on the cotton towel, you will see some ink come out of the cartridge, if yes, then put the cartridge back into the printer, and give it a try.
if not try to blow some air into the cartridge as if doing CPR ;) to the cartridge, this will help the ink get out of the cartridge.
if all this fails, get a new cartridge, as sometimes the head could have gotten damaged.
good luck
Mar 25, 2009 | Dell A940 All-In-One InkJet Printer
Dell 3110cn color laser prints with black "haze" on all pages
You probably used a "GENERIC" toner cartridge on one of your toners.
This caused the developers to get contaminated, now they need to be replaced (probably Black & Blue)
Jan 12, 2009 | Dell 5100cn Laser Printer
How can I print a color picture without using a black catridge?
Black ink is an essential part of the printing process. The black color is only made by the black cartridge, the color cartridge does make "black".
One or more optional photo cartridges may be available, depending on your printer model.
  • Use the photo cartridge with a tri-color cartridge for best-quality color photos and graphics, and sepia or antique photos.
  • Choose a gray photo cartridge to print black and white photos with truer grays and richer blacks.
Nov 21, 2008 | HP DeskJet F380 All-In-One Printer
Can this machine COPY from the Black Cartridge only.
Click Start - All programs - HP - HP Director/Solution center.
In HP Director/Solution center. Click Settings - print settings - printer settings . Click on the Colors tab. Enable the option Print in grayscale and Black print cartridge only.
This is the only way to print with single black cartridge.
Thanks
Dec 21, 2007 | HP OfficeJet 7410 All-In-One InkJet...
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
497 people viewed this question
k24674
jasbo
jasbo
