Question about Printek FormsMaster 8003 Matrix Printer
Need to Tighten the Tension on the Printer Cartridge
Hello, we have a Printek 8003 Forms Master. We've just changed the cartridge in the printer; however, in the middle of our forms, it appears the tension on the cartridge is not tight enough because the top of the form looks fine and is readable; however, toward the middle of the form, the numbers, information, etc. are printing very lightly, like the tension is inconsistent. Then, the back copies of our 5 ply non-carbon forms aren't near readable. We could use your help or advise on this!
3 Suggested Answers
macminiguy
  • 34 Answers
SOURCE: PRINTER WON'T PRINT WITH COMPATIBLE RIBBON
You need to go to setup and scroll to options menu, there you'll find :"Ribbon check" , turn it off and your good to go!
Posted on Mar 03, 2009
RoryMRP
  • 111 Answers
SOURCE: printek 8003 printer gets false paper jams when
Have changed out the Jam detection sensor? That is the black paper guide with a wheel in the center of the assy?
If you have any questions please contact me we offer free technical support and carry all parts for Printek units New and Refurbished.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
3821 W. 127th Place
708-597-4222 x24
rcardenas@mrp.to
AOL IM: RORYMPR
Posted on Jul 29, 2009
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
Hello I have a Lexmark X4650 printer. I was printing earlier this morning and then suddenly, the printer stopped working and gave the error message that left cartridge is incorrect (I haven't...
Good job in re-seating the cartridges into the printer. Try to insert a different known working cartridge to determine if your other cartridge has gone bad.
Jul 24, 2011 | Lexmark X4650 InkJet Printer
We tried to change settings for forms and now it said it is disabled
Give Printek tech support a call at 800-368-463. I've always found them very helpful.
Jul 19, 2011 | Printek FormsMaster 8003se Printer
Error light keeps blinking and i changed all the toners
Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
Jan 30, 2010 | Dell 1320c Laser Printer
Keeps messing up print heads. i just replaced one about a month and a have ago. and i am having with it again. it is tearing paper and missing dots .. i had replace one another one 6months eariler.
It seems to me like you have a gap issue but I was wondering if you might be able to call in and talk with my technical support team. They have 10+ years experience on Printek Printers and we are an ASR for Printek. We carry new and used parts for all Printek printers.
Technical support is free and can save people a lot of money.
Please give me a call and ask for Rory, I will then transfer you over to technical support.
Thanks,
Rory Cardenas
3821 W. 127th Place
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jun 29, 2009 | Printek FormsMaster 8003 Matrix Printer
I have a broken carriage drive belt. do you have the p/n.
I do have the carriage belt and Manual that you are looking for new in stock along with all other parts. I am an ASR for Printek.
Please contact me back if still in need.
Thanks
Rory Cardenas
3821 W 127th St.
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Apr 30, 2009 | Printek FormsMaster 8003 Matrix Printer
Printek 8003 printer gets false paper jams when trying to load from any one of the three tractors. We have changed the paper out sensor, edge sensor, power driverr pwa, logic board, and backplane.
Thanks
Rory Cardenas
Alsip IL 60803
3821 W. 127th Place
708-597-4222 x24
rcardenas@mrp.to
AOL IM: RORYMPR
Mar 05, 2009 | Printek FormsMaster 8003 Matrix Printer
Nov 10, 2008 | Printek FormsMaster 8003 Matrix Printer
Can't use compatible ink
You need a chip-resetting tool.
Or use the printers software utilitie changing ink cartridge, some printers insist that you go into your printer software/program. to inform or communicate with the printer, that you are changing a Cartridge. then the printer, will move the printhead to the desired position, to remove the cartridge.
When the new cartridge is installed, the printer is set to look for new changes. make sure you,ve inserted the cartridge fully into it,s slot ( holder ) push until you get a slight click.
If you,ve disabled Status monitor, then your printer cannot output the Cartridge Status. ( empty-Full )
mike @ Compurepair.
Feb 25, 2008 | Office Equipment & Supplies
Brand New Printer
Hi Teetle, No, it not normal to only get two pages per cartridge. I would try the following before contacting Epson tech support: -Remove the cartridges and clean the contacts on both the printer and cartridge. -Reinsert each cartridge making sure it is seated correctly. -Buy one black cartridge and install. It is possible that the cartridge is defective but since the magenta cartridge is showing low its unlikely. Tech support will want you to try it before they will replace the printer so you?re best off trying it now. If after trying this steps there is no change and if you?ve had it for less than 7 days I would talk to your retail store. Usually they will just trade your defective unit for one in stock. If you have had it longer contact Epson support and explain what it happening and what you?ve done. Make sure you mention you?ve bought a new Epson black cartridge with no change. Let us know if you have any other questions and please don?t forget to rate this post.
Jan 20, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Printek FormsMaster 8003 Matrix Printer Logo
48 people viewed this question
Top Printek Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Printek Office Equipment and Supply Expert? Answer questions, earn points and help others
