Question about Frigidaire Refrigerators
Refrigerator - water dripping out from freezer
Water will intermittently drip form the freezer. It appears to be coming from the vent at the bottom of the freezer.
    Sergeant:
    Champion:
  • 251 Answers
It is auto defrosting
Posted on Nov 26, 2008
The top of the inside of my 2002 Whirlpool refrigerator Model ET1FTK (top mount)is frozen and is dripping onto the first shelf.
The cause of that drip is going to be a blocked defrost drain in the freezer and the water from the defrost is pooling up in the freezer then when it can't hold anymore it's dripping through the vent in the ceiling of the refrigerator onto the shelfs. By removing the back wall of the freezer you could find the drain on the bottom of the freezer coil. By GENTLY peircing that frozen drain at a 45 degree angle until a small hole is formed in the built up ice it could be totally flushed using warm water once a small opening is made in the ice in the drain.
GENE
Oct 13, 2011 | Refrigerators
Water collecting under bottom draws inside frig
That water is very likely dripping from the freezer because the drain for the defrost is blocked,so instead of the water draining its dripping through the vents down under the crispers. This tip i wrote will help ya to clear that drain to keep the water from dripping through the vents.
http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Magic Chef CTF1826AR Top Freezer...
Water dripping in refrigerator from ice forming in top rear of refrigerator. Ice has formed below what we think is the automatic defroster and is dripping water into the the main part of the refrigerator....
You have a drain clogged at the bottom of the evaporator inside freezer compartment. You'll need to remove all contents put towel inside, turn off, pull out to access back of fridge, pull drain line off or check at bottom in pan where it normally drains, you can melt ice at top of tube with hot water,hence the towells. this is a messy job usually takes about a good hour to get it right, just perservere. I will fix it, when you get it cleared. I have employed a coat hanger to speed things along as a tech it is the call I dread because of the mess.
Good Luck,Masta tech
Aug 21, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Water leaking from freezer forms ice on bottom of the freezer needs to be removed every week or leaks onto the kitchen floor. water coming from back wall of freezer from what appears to be vent cracks in...
Hello and Welcome to FixYa!
Well, it seems like the drain pipe or the drain channel is clogged, and the defrost water from the evaporator coils is dripping through the quoted regions, down to the base. Try checking the drain hose/ channel and remove the clogging if any (Blow some moderate temperature air through the channel and check/ remove any permanent clogging If any). Feel free to ask the details, or any question relevant to the trouble..
Concerned.
Aug 11, 2011 | LG LRDC22731 Bottom Freezer Refrigerator
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Water weeping out vents in lower back of freezer compartment
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water drips from evaporator fan channel Frigidaire FRT17G4B
It sounds as if this is a top mounted refrigerator. (freezer on top) If this is the case, check to see if you need to defrost the drain. You could also have a problem with the door seals. Remember the air coming out of the vent is freezer temp minus a few degrees. It could be that the moisture is condensing in that area.
Feb 01, 2009 | Frigidaire FRT17G4B Top Freezer...
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
81 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
