Question about Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-S4252 gaseous smelling smoke and loss of picture
Was watching tv when smoke emanated from the back of the tv, followed by screen going out; I pulled power cord out and have not attempted to run since.
  • Anonymous Dec 28, 2008
    Same problem as above, smell of smoke, then no picture. Just audio. When we turn the tv off and back on, the picture comes back for 15 seconds or so and then it's gone again.
    We have had the tv (Samsung HP-S4252) for a little over 2 years. Yes, out of warrantee.
  • Samsung Master
  • 5,568 Answers
Unfortunately, your problem is familiar; the odor you smelled was signaling the death of an electrolytic capacitor.
The electrolyte gassed off after the part grew hot and finally burst.
You will not likely be able to do the repair yourself since the cap could have first been destroyed by the failure of a diode rectifier so replacing the cap may not cure the problem.
If you are adventurous, you might pull the plug on the set, allow the set to sit overnight, gain access to the innards, and with good light, inspect any boards inside.
If you see one that has few ICs but many more larger discrete parts, this will be the power supply.
Again, before touching anything inside, especially on that board, allow at least several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
You are looking for components called electrolytic capacitors that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many failed caps (not all) will show signs of pregnancy when they fail, bulging unnaturally at the top when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will be four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006. This is due to the use of a defective chemical made in China and used in millions of parts made by other companies, never suspecting that they were building time-bombs doomed to fail.
The larger caps may be OK since the failure is likely related to functions other than brute-force filtering. A pretty good 'rule of thumb' is to replace any caps you see bulging of any value but especially those that are 100 uFd or less.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace it or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
If you choose to replace failed caps yourself, you will need a quality soldering iron with a small, preferably iron-plated tip, rosin core solder and a sponge which when wetted is used to frequently wipe oxidized solder from the tip. This should be kept bright and clean and fresh tinning will keep it that way.
You should also buy some solder 'wick' with the iron; this is used to place on the solder you wish to remove and then heated with the iron. Properly used, the wick will absorb nearly all of the solder from the lands from which you wish to remove a component.
Avoid lingering too long on the soldered area since this can cause the trace's bond with the board to yield, lifting the trace.
Posted on Nov 26, 2008
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
Aug 31, 2012 - Uploaded by
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ... > ... > Electronics
Jan 26, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Televison & Video
Samsung LN46C550 TV does not turn on
There could have been a power supply failure without any noticeable symptoms.
Dec 18, 2013 | Samsung LN46C550 TV
Techwood 42" plasma screen television
Do not turn this television on! Any electronic that smokes is NOT GOOD! The smoke and accompanying smell is from plastic and solder that is being melted by a short on one of the TVs logic boards. Call a local TV repair man this is not an issue you could fix yourself and will most likely be better off buying a new television. Stay away from off brands like these, spend the few extra bucks on a name brand like Sony, Toshiba, LG, or Samsung and you won't encounter these types of issues.
Feb 15, 2011 | Samsung SPN4235 42 in. Plasma HDTV
Smoke emanates after printing a few copies please help
Not a good sign. Is it a paper smoke smell or an electrical smell. If it is an electrical smell then the printer is faulty. I suggest you get a new printer.
If it is a burnt paper smell then it most likely a paper jamb at the fuser unit. Remove the toner cartridge to get access to the fuser and remove the paper (let the printer cool down first because the fuser unit is very hot).
Nov 26, 2009 | HP LaserJet 1010 Printer
Samsung le26r51bd picture loss.
it is problem your tv high voltage (EHT) not properly supply or creats high voltage
Nov 22, 2009 | RCA D52W19 52" Rear Projection Television
Samsung Rear Projection SP43W6HFX- Smoke + Blurred Vision
Convergence IC's are it. You'll find loads of solutions!
Nov 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HP-R4252 42 in. Plasma HDTV Logo
182 people viewed this question
Jerry Greenberg
Jerry Greenberg
