Question about Honeywell Heating & Cooling
I can not get the humidistat to regulate the humidity levelin my house to match the hygrometer reading.
  • 61 Answers
You will need a better instrument to test to see which one is off the humidistat or the hydrometer.
Posted on Nov 30, 2008
Why does the humidity in my house go up when the furnace is on?
Humidifiers are usually controlled by a humidistat that reads the humidity in your house and turns the water on and off to humidifier that is attached to your furnace. When your furnace is running it sends the voltage through your humidistat that then runs water through a filter screen inside humidifier and the furnace forces air through this screen which places humidity into your home. If humidity too high look at dropping level on humidistat control. (Usually attached to ductwork bye furnace)
Nov 03, 2013 | Heating & Cooling
Why do I need a hygrometer for?
You don't have to have it unless you are a Meteorologists that likes to measure the humidity in the air which might help predicting the weather.
Read more here: http://www.ehow.com/facts_5051938_hygrometer-used.html
Jan 30, 2013 | Measuring Tools & Sensors
The Hygrometer on my Air-O-Swiss U7142 reads 25% all the time. I assume its not functioning properly as I have other hygrometers in the house which say higher readings. Is there a known way to fix this? I...
I have got the same problem with my u7142 unit. This most probably means that the hygrostat inside is either broken or it has been heavily covered with the "white dust" in case the demineralization cartridge has not been changed for a long while.
To resolve it you have two options: either clean the humidity sensor or replace it. The sensor is at the bottom of the front panel, so you need to disassemble the front panel only, no need to open the whole unit (note that there are 2 screws at the bottom holding the front panel also). You need to get the sensor out from the printed circuit to open the cover and clean the surface of the sensor with something (blowing air does not help; you need physically touch the surface with something). If it does not help then you can go for the second option to replace the sensor, the type used in the unit is SYH-1. It is not a pricy element so you may go straight to the replacement if you find a shop nearby to buy it. I have simply replaced the sensor and now the unit is showing the proper humidity value and adjusting the steam automatically again.
Mar 03, 2011 | Air-O-Swiss U7142 Humidifier
No humidity in the house
Hello, the first to confirm is if you are receiving 24 volts at the transformer, if you are then check for 24 volts going into the humidistat and out of the humidistat, if voltage is confirmed there then check if your solenoid is recieving 24 volts, if it is and the solenoid is not letting water into the humidifier than your solenoid is bad and must be replaced. If you do not have 24 volts at the transformer then turn off power to the transformer and set your meter to read continuity, you should have resistance if not the transformer is bad and must be replaced. If you have power to the humidifier and not humidifieing properly then you have to set the humidistat according to what the outdoor temp is, the outside temp determines what setting and % of humidity you should have in your home. Here is a what it should be
-20 set to 15%
-10 set to 20%
0 set to 25%
10 set to 30%
20 set to 35%
above 30 set to 40%
Jan 25, 2011 | Honeywell HE365 Humidifier
Too much humidity in house water sitting on windows
Adjust your humidistat to lower humidity level. If you do not have a humidistat, get one and install following mfg guidelines. Home Depot sells one for about $30
Search home depot for H8908B1002
Dec 25, 2009 | Honeywell Humidifiers
Hi I need help understanding the controls to my humidistat. I have a honeywell a/c unit so I'm assuming the gold colored humistat next to it is also honeywell. I bought a digital temperature and humitiy...
The higher the % of RH, (relative humidity), the more humid the house will be. I would disregard the temp part of the dial, and focus more on your comfort. Adjust it up daily until you reach a satisfactory humidity level. Hope this helps
Dec 19, 2009 | Honeywell Power Humidifier: Furnace...
Aprilaire 560 will only click and flow water when turned to "test" does not work in any other settings?
Humidity must be hi enough in the house or Humidistat is not working. Do you any way to check humidity in the house?
If the Humidistat is set as Automatic, try to leave it as Manual.
Dec 03, 2009 | Aprilaire 700 Humidifier
Humidity levels vs. hydrometer
I had the opposite problem - I set mine to 55, and my hygrometer was reading 67. Turns out the hygrometer was way off, and the humidifier was very close to maintaining what it was set to. Did you try the salt/water method to check the calibration of your hygrometer?
Aug 22, 2008 | Kenmore 54501 Dehumidifier
Works too well, can't stop windows from sweating!
I don't know much about humidifiers other than they are rarely needed and most folk around here would rather there was a lot less humidity., especially considering how easily black mould grows and how injurious to health that can be.
Those few people living with an unsuitable heating system in a badly designed house usually find it is adequate to have a water feature in the lounge or to balance a bowl of water on a radiator.
Certainly when the windows sweat to such a degree, especially if you have double glazing, the humidity must be well above the comfort range, above 70%, and probably well into the moist range of 80% - 90%. Higher than that and any exertion becomes decidedly unconfortable...
I am guessing the humidistat is either faulty or cannot work because the humidity is already too high. I suggest you need to check the humidity in your home with an accurate independent humidity meter before you go further...
Mar 24, 2017 | Honeywell HE220A1019 Whole House...
Heating & Cooling Logo
54 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
