Question about RCA 27F650T 27" TV
Tv is not working
I turn some kind of lock on in settings which turned all buttons off I shut TV off and now it wont go back on I unplugged it for a day but nothing has worked what is the problem
  • Anonymous Apr 16, 2008
    I am looking for TV ADDRESS CODE for universal remote
    Scholar:
  • 168 Answers
The symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician
Posted on Jan 16, 2007
SOURCE:
I have same problem as OP: "My remote and the
Still have same problems,tv tries unplug,replug about an hour to reset back to the factory setting.Than ur tv Tuner board signal board have shorted some parts insides.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 28, 2010 | Panasonic TH-42PX60U Television
When i turn my tv on it says FDA Lock ON and then it turns itself off and wont come back on. it shows the power button is lit up but it has no picture and no sound. we have tried to reset the password to...
Hello
Your TV is locked I thinks. Do the following and see whether it help you.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Dec 20, 2010 | RCA TruFlat 27F520T 27" TV
Parental lock
just disturb it
switch on and off on and off be fast
or switch on with program button pressed
it will unlock
Mar 20, 2009 | Philips Magnavox 13MT143S 13" TV
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
Wont turn on
You will need to do a hard reset on the TV. Unplug the TV for 5 hours. This should clear any sofe codes set on the TV. Then plug it back in and turn it on. This should work.
Apr 06, 2008 | RCA 20F512T 20" TV
Scrolling
Sounds like it has one of two problems first one could be a stuck button. The micro locks up and the set wont come on also could be causing the channel scrolling run you finger along the channel buttons. Other than that you would need a new signal board you have a locked up micro...this part will be No longer Available.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
Tv wont turn on
If the power button on the TV (or on most Philips units ANY button press) doesn't turn it on, it has a failure or is unplugged. How can you not know this??
Oct 13, 2007 | Philips Magnavox 27MS343S 27" TV
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV wont turn off
IT COULD BE THAT THERE IS SOME METAL DEBRI IN BETWEEN THE TWO BUTTONS ON THE MOTHER - CIRCUIT - BOARD YOU CAN UNPLUG THE TV OPEN IT UP THERE IS I BELIEVE 4 SCREWS THAT HOLD THE BLACK COVER ON THE BACK THEN THERE SHOULD BE TWO BUTTONS THAT HOLD THE CIRCUIT BOARD PULL IT OUT VERY CAREFULLY AND LOOK OUT FOR DEBRI. YOU COULD CLEAN IT WITH DISTILLED ALCOHOL AND A SOFT BRUSH YOU WILL HAVE TO UNPLUG THE SPEAKER CONNECTOR ON THE LEFT SIDE ALSO ANOTHER CONNECTOR THAT COME FROM THE TUBE HOPE THIS HELPS
May 04, 2007 | Toshiba MD13P3 13 in. TV/DVD Combo
RCA 27F650T 27" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
