Question about Husqvarna Huskylock Computerized 936
Fabric select button does not work.
Cannot get the machine away from "Woven Medium" and also unable to delete a memory. It would appear that the fabric select button has failed.
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Sounds like it's time for service by an authorized Husqvarna Viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 13, 2010
HELP! I have a brother 1034d the thread is stacking up on the little fingers on the needle plate
I have the same problem. The serger is making the chain, but it's not moving off the stitch finger! I have to pull it while im operating it (with force) and when i put fabric, it bunches up like crazy and i just broke a needle... Any clue anyone?? Here is a picture... https://goo.gl/fhqq15
Apr 23, 2017 | Brother Sewing Machines
Sewing a hem on a sheer (rayon ?) curtain and it puckered slightly along the seamline Used sz 11 ballpoint needle with 40wt rayon thread. Tried tiny stitches then longer ones. Any suggestions??
well aside from trying all the normal things like thread tension adjustments and such , another neet little method is to use a flat piece of thin tissue paper (sew right thru it ) layed over fabric , this will add the stiffness to fabric u may need to complete this task, then very slow and carefull tear the paper away from it to leave the threads behind!! if you think you can get away with it use tissue paper on back side and leave it there , hey holds a hem and pleats real nice !!
Dec 21, 2016 | Sewing Machines
HV sapphire 930 not feeding properly
When stitching together a quilt sandwich, it is recommended to use a walking foot on your machine. The walking foot moves the upper fabric in conjunction with the feed dogs. Sometimes, if the quilt sandwich is not too thick, a roller foot can also help but may not be sufficient for a quilt sandwich.
What is Walking Foot Sewing Tips for Beginners
How To Use Walking Foot
How to Use Roller Foot
You may also check the presser foot pressure on your machine. This regulates the amount of pressure the presser foot applies to the fabric and the feed dogs. If the pressure is too strong, it will tend to push the upper layers of fabric, creating a bubble look. If the pressure is too loose, there is not enough pressure for the feed dogs to physically pull entire quilt sandwich under the presser foot.
(The pressure is adjustable depending on the types of fabric and thicknesses being sewn.)
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Oct 01, 2016 | Sewing Machines
My stitch length is tiny and will not change
When selecting a stich, there's a button with a triangle with one edge pointing down. There you can select Needle Position and Stitch Length. --PDF manual, page 23
The thread tension has no influence on the stitch length. It just adjusts, where needle thread and bobbin thread 'meet' inside the fabric. A too high tension means, the bobbin thread is pulled trough the fabric and can be seen on the upper (needle) side. A too low tension means, the bobbin thread is not pulled through the fabric and you can see the needle thread on the bobbin side.
Jul 08, 2014 | Janome Memory Craft 9000 Computerized...
Husqvarna lily bobbin tension issues
Not sure if I can help, but it may have to do with the heavy thread as well as the fabric and needle combination. If the fabric is thick or tightly woven, be sure to use a brand new sharp needle. (If the fabric is tightly woven (like Batik), a thicker thread may present a problem.) In your case, if using a heavier thread, perhaps a top-stitch needle would be beneficial since it has a bigger scarf to protect the thread. With the heavier thread in the top, the top tension will need to loosened. BUT, if you loaded the heavier thread in the bobbin, the bobbin tension will need to be adjusted to accommodate the thread thickness. However, remember that if you adjust the bobbin tension for this project, you will most likely need to readjust it for the next project using different materials.
FWIW, if the machine still works fine with regular fabric and thread, then you'll know that the issues revolve around the current project.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 11, 2017 | Husqvarna Sewing Machines
How can I program a full name into my 1+Husquvarna Sewing machine?
I have the #1 and it should be similar in programming if not the same.
Instructions for the #1 (1200) -- Programming Block Letters
(one model down from the #1+ Husqvarna)
From the machine instruction page for letters and numbers
Ready:
  • .Fabric Woven-medium, stitch & tear
  • .Enter: Woven-medium on your sewing advisor
  • .Consult Info display: Presser Foot B
Program:
Insert Cassette B
  • .Touch SELECT function to PROG
  • .Advance to an empty memory
  • (->) means arrow: .Touch H-> U-> S-> Q-> V-> A-> R-> N-> A (STOP) -> REP
Sew:
  • .Place Stitch & Tear against the wrong side of your fabric.
  • .Stitch the word HUSQVARNA. Easy!
  • .Now, program your name and today's date. Stitch on your sample.
Smaller sizes of letters
You can program a number of letter sizes by - the width before entering the letter. You may want to enter the first letter of a name at 6.0 width and the other letters narrower.
Correcting Errors
You may clear any single stitch but the first one on a program. When the cursor is under the first stitch and you touch CLR, the entire program is erased.
NOTE: The cursor designates the first letter to be sewn.
Oct 15, 2011 | Husqvarna Viking 1
I'm doing a monogram embroidery on hankerchiefs and I don't like the tension. The bottom is too tight and the top loops are showing too much on the back. What to do? I have a Designer 1 Viking machine. I...
first I would switch to same color thread on top as well as the back second I would change to the fabric that I was sewing on woven med. then I would use two layers of wash away med stabilizer to sew on on the back this will help with the tensions
Oct 14, 2009 | Husqvarna Sewing Machines
Loose thread tension
You should be able to sew with the tension on 4 for most applications. The only time I've had to change it is for elastic.  I usually sew elastic on 7.   In my experience, when the tension doesn't seem right, I've got the wrong needle for the fabric.  Needles are color coded.  The top of the shank will be yellow or red, for knit or woven fabric.  There will be a band below that of orange, blue or purple for light, medium or heavy fabric.  You want to make sure you have the right needle for your fabric or it isn't going to sew well.  The only things I haven't been able to sew on this machine have been lightweight jersey knit and a really high twist twill.  It would do five layers of twill, but since I'd used twill for the pockets too, it wouldn't do six layers where the seam met the pockets.  I had to get a friend to do that on a commercial machine.  Jersey knit it likes to stuff down into the bobbin case.  I've heard it would do it with a straight stitch foot.  Regardless, you have to pay attention to needle selection.
Mar 08, 2009 | Brother XL-3500
Huskylock 936 fabric select button not working
Sounds like time for service by an authorized Husqvarna Viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 26, 2008 | Husqvarna Huskylock Computerized 936
Sewing Machines Logo
59 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
