Question about Fuji FinePix Z10fd Digital Camera
Sd memory card- on camera reads card error I took some pictures off my computer put them on my SD card to view in my camera. They are pictures I had take on the same camera, but I am getting read error. Looking for whats going on???
  • 477 Answers
Sience they are on your computer try to format the card with the camera. see if you still get the error if you do then try a diffrent card if the camera is still having the issue then you problem lies in the camera's card reader writer. and the main board might need to be replaced. this can run any where from 75.00 and up depending on the full issue. please if you need any further help let me know.
Posted on Nov 26, 2008
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
I have an Akai DC6371 digital camera and the card I have in it is a Kodak 128mb SD card. However, the camera will only let me save 4 pics to the SD card. I tried putting a different card in it that's...
Hi I can tell that sometime you have to format within computer using external memory card reader, not from camera. It is not recommend switching around one sd card to another camera. It cause card error. If you want to use it, then you have to save pictures somewhere in other storage or computer, and format the one you want to use in computer using external memory card reader. And then one more time format in camera (you have to insert memory card into camera) These method very helpful on like your problem. If not working, then you have either camera defective or memory defective. Thanks and best regard!
May 25, 2011 | Akai DC6371 Digital Camera
After a birthday dinner, i plugged my sd card into my computer to upload my pictures only to find that a couple of them were corrupt and couldn't even be viewed. I put the sd card back into my Canon...
Most probably the problem is in SD card. Please try a different card to check. Also perform scandisk on this SD card to check for errors.
May 14, 2011 | Cameras
Can't Transfer Photos From SD Card To Computer
were pic on camera before you started;if so it should work'
May 01, 2010 | SanDisk 2GB microSD Memory Card
SONY DCS T1 FORMAT ERROR C:13:01
Hi.. I think you have solved the problem yourself... replace the adapter with a memory stick... You have eliminated the micro sd card as bad... now try a new known good memory stick..
Thanks
jim
Feb 18, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
'File error' message on samsung L200 camera when viewing a photo
Possible solution:
I had/have the same problem using L200 and SDHC memory card, called Samsung. Can't view certain pictures on camera or computer, camera freezes when viewing those certain pictures, green light flashing.
Samsung support told me that I needed to copy my (good) pictures to a computer first because a memory format will erase everything. Then format (menu->settings->format->yes) my memory card. Tried this just now and took some new pictures, so far so good.
Jan 15, 2009 | Samsung L200 Digital Camera
Sd memory card cannot be used
This happenes when you remove the card while read/write process is still going on. Try some professional service who will retive the data for you from the mem card. Hope this helps.
Dec 27, 2008 | Nikon Coolpix L11 Digital Camera
Pictures
You have to make sure that the sd memory card you were using, hasn't been in another camera. If it was, your camera read the memory card differently, and it didn't show you had taken any. If this was the case, put the sd card back into the camera you took it from, and hopfully it will show on that.
If I wasn't even close, put you sd memory card in your computer, and hopefully, they will show up on there.
I'm sorry if I didn't get what you were saying, and didn't even answer you problem. I hope this helps.
Oct 01, 2008 | Nikon Coolpix L11 Digital Camera
Lost Pics
Memory card error is common problems in various sd cards and cf cards. I took a closer look at my little SD memory card. It has a sliding lock on it to protect data. Check to see if the card works when you slide that lock up or down. Read more about memory card:
http://www.uflysoft.com/data-recovery-mac/memory-card-error.html
May 14, 2008 | Sony Cybershot DSC-T200 Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
98 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
