Question about Garden
I have a riding mower and I ran into my house. Now when I crank the mower it cuts off when i disengage to lower the blades.
    Scholar:
  • 36 Answers
Check the wiring around the deck, as all ride on mowers have a cutout system wired to the deck, seat, & also on the rear basket.
One of these wires must be getting earthed to ground causing the engine to shut down.
In most cases I see a lot of mowers coming in with these wires removed . This is not good practice as you could get your toenails trimmed when getting off the mower. So we always replace them !
Posted on Nov 27, 2008
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
Vibrations when the cutting head is lowered . Sounds like one of the blades is hitting the cover. Especially noticeable below a setting of 5. Three cutting blades. There is no noticeable loss of cutting...
Sounds like a bent blade to me. Can you determine where or which side the noise is coming from? For safety, I would replace all the blades. I once ran over my son's baseball while mowing and bent the housing and that caused the blade to hit the side of the deck. I simply bent the housing back with a few hits of a hammer and back to mowing I went.
Jul 04, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I cannot disengage the cutting attachment so that the mower will start; it seems like it is stuck, because when I attempt to disengage the blades the lever will not move into the disengaged position. How...
You haven't specified the model number, but pretty much all riding mowers use a plunger-type electrical switch to engage the mower. If it's stuck in the 'lifted' position (mower engaged) then it has broken internally. You must replace it. In doing that, the wires need to be placed back on the correct terminals, so take a picture of the wires (showing their colors) before you disconnect them from the switch. Take the broken switch to a lawnmower shop to find a replacement. Shouldn't be more than $10 - $20. Good luck! Please rate my solution if you found it helpful.
Jul 03, 2010 | Craftsman Garden
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Poulan 38" 15.5 hp lawn mower cuts off when blades engaged.
you have a bad blad saftey swich that all it is replace that and youll be good to go
Oct 01, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a husqvarna 172 ride-on lawnmower. Running
This unit probably has a safety switch built into it and it could be below the gas tank. If this switch isn't adjusted properly then it's designed to cut off the motor. I think you should concentrate on that before attempting anything else.
Aug 02, 2009 | Garden
Mower blades not engaging
is the mower belt on the pulley ?
Jun 12, 2009 | Garden
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
