Question about HP Office Equipment & Supplies
How to place the catridges in the printer
Ihave HPPSE 1402 ALL-in -One
  • 300 Answers
This link should give you step by step instruction on changing/inserting the cartridges.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 26, 2008
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
WHEN I PLACED THE BOTH CARTIDGE AT THE PLACE AND SATR WORKING THEN THERE IS LIGHT BLINKING ON THE DOWN OF PIWER LED WHAT IS THE REGION
try putting one catridge at a time. whwn you put black catridge alone and the blinking stopes then colour could be damaged. and viseversa. find deficative and replace catridge
Feb 07, 2011 | HP DeskJet F380 All-In-One Printer
I put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Nov 29, 2009 | Lexmark X6570 InkJet Printer
INk LOW DISPLAY DOESNT RESET AFTER RENEWAL
Dear Sir,
Here is the Solution,
By using mp tool software we can resett ink levels,mptool is the popularness software to reset printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460. Excess of software that is the program measure of small and amenity of usage. Ability of the software that is to reset level black and color cartridge at canon pixma mp series. And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Download Mp tool
this solution deffinately solves your problem
Aug 27, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Printer keeps saying unable to print
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer
Good Luck
May 06, 2009 | Brother MFC 420CN All-In-One InkJet...
CANNOT FIT IN THE REMOVED INK CATRIDGES INSIDE CATRIDGE HOLDER
I located a printer repair service prson locally who fixed the problem, taking printer to his service centre.Now it's OK.
May 05, 2009 | Office Equipment & Supplies
Catridge eroor
HP27 or HP56 is the compatible cartridge only.
Apr 02, 2009 | HP Officejet 4355 All-In-One InkJet...
Kyocera FS-2000D is printing a grey stripe down the side of page
In this case what i would request u to do is.......
Know insert both the catridges inside the Printer...........
Good Luck
Feb 16, 2009 | Kyocera FS-2000D Laser Printer
Dell 964 printer reads color but not black cartridge
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer...... Now try to Print it will work Fine......................
Feb 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
42 people viewed this question
Ben Johnson
